I got a cc hydra ice 240 wanted if any you guys this esc and what do you think about it compared to s/f 240hv
hydra ice 240
Tags: None
I have run an ICE240 for over a year without problems - that includes a lot of SAW runs setting records. After the SAW race the ICE went into my P Sport Hydro and was raced a lot. Zero problems, it is rock solid. The datalogging feature is wonderful, the Swordfish does not have that feature. The ICE has a maximum voltage of 8S while the Swordfish can handle up to 12S, that could be the deciding factor.
Fluid, Do you use the internal BEC or seperate battery power sorce for receiver and servos. I have heard BEC works good up to 6s. Questionable on 8s.Originally posted by Fluid View PostI have run an ICE240 for over a year without problems - that includes a lot of SAW runs setting records. After the SAW race the ICE went into my P Sport Hydro and was raced a lot. Zero problems, it is rock solid. The datalogging feature is wonderful, the Swordfish does not have that feature. The ICE has a maximum voltage of 8S while the Swordfish can handle up to 12S, that could be the deciding factor.
Just to clarify the ICE 240 works great on 8S, but the BEC circuit seems more vulnerable so I would recommend removing the middle power wire and running an external reciever battery.
TylerTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
swordfish models have the logging options now. For the swordfish 240hv OSE only stocks the version with no logging feature. Because the added cost of logging brought the cost close to the cost of the swordfish 300 pro plus with logging.Steven Vaccaro
Be sure to enter Pole Count and KV of motor to get acurate rpm reading on graph. You do this by clicking Window icon button named Castle Link Graph Viewer. When graph screen pops up you will see edit at top. Click on edit then click on change motor pole count/gearing
