Apparition Offshore Brushless single motor
  • medina619
    • 63
    true id rather order from OSE, if you have some links to parts that would be recommended for the apparition please post them up
    The Brushless crew!
    Losi Ten SCTE/Team Associated SC10/Axial Exo Terra/Apparition Offshore Brushless
    • boddenboys4
      • Jan 2012
      • 94
      I have a single motor apparition that I have upgraded the motor to a 1520 Castle/Neu. I had to modify the hatch to make it fit. So far I've done a few runs on 6s. Word of advice, if you go to this size motor, do an inlay of CF or CK, that's where I'm at now. I'm still running the .150 flex but will have to upgrade I know to the 3/16. The ESC is the turnigy 180, I'm looking to go to the FC 2-8s 240A, the motor can be run @ 8s for SAW runs so that's where I'm headed. Its already a monster @ 6s. The props I've run are the X440 and 545, as soon as I get it back together I will test a 645 Aluminium prop from FC.
      • medina619
        • 63
        i dont want to go that big a 3674 will do.
        The Brushless crew!
        • medina619
          • 63
          so i made my choice and went with the LEOPARD 3674 KV2200 4 Poles Brushless Motor. i hope it does well
          The Brushless crew!
          • LOVE6S
            • May 2012
            • 538
            I just got those two 1900 kv motors from HK today in the mail, not sure what boat I am gona use it in, but I cant wait to see how it performs, it looks well made, let me know how you like the 3674 2200 kv, your gona run it on 4s correct? Shawn.
            • medina619
              • 63
              Yea we will swap results.I want to see how that motor you got performs
              The Brushless crew!
              • medina619
                • 63
                anyone know if this is the correct fit for the apparition prop shaft?
                http://www.offshoreelectrics.com/pro...rod=octsb-x442
                The Brushless crew!
                • medina619
                  • 63
                  new 3674 leopard 2200kv motor is in! cant wait for the weekend!!! any prop recommendations?
                  The Brushless crew!
                  • 785boats
                    Wet Track Racing
                    • 3423
                    X440/3 blade is a good prop for that motor & that size cat. For short runs an X642 is quick.
                    What ESC are you running. You should use at least a 180A.
                    Be sure to set your ESC timing to low ( Around 1 - 3 degrees is good) because the motor you have is a D wind.
                    • Alexgar
                      • Aug 2009
                      • 3701
                      Im runnig a cc1515 2200 on a t180 with a m545 bsp prop on 4s 40c and runtime is limited cause i cant fit a water jacket on mine but by far one of my fastest most relieable boats
                      • Alexgar
                        • Aug 2009
                        • 3701
                        apparition
                        this is her on the same setup but an etti 150 that was smoking untill a water clog malfuntion tok care of that t180 much more robust and i use onr on my sc truck mever a heat problem even though its a water cooled esc being cooled with air
                        • medina619
                          • 63
                          HERE IT IS!
                          The Brushless crew!
                          • LOVE6S
                            • May 2012
                            • 538
                            Did you pick a prop, what came with it?
                            • medina619
                              • 63
                              i picked a prop but i haven't ordered it(out of stock). im going to order th following
                              X442 prop
                              4mm to 3/16" Prop adapter
                              http://www.offshoreelectrics.com/pro...?prod=ose-1030
                              The Brushless crew!
                              • medina619
                                • 63
                                going out today and do some testing
                                The Brushless crew!
