Does this sound about right?
  • jamespl
    • 748
    Decided to use my iPhone as a gps device! So I put it in my pursuit, it gps'd at 42mph, does that sound about right? My setup is a turnigy XK-4074 2000kv, T180 esc and an x642 prop running 2x2s 7.4v 6000mah 25c batteries. I realise that they aren't my best batteries and it did seem a little faster on my 5900mah 60c batteries. I'm thinking of trying an m445 but the ec5 connectors get pretty hot. The motor is hardly warm and the esc isnt too hot either I'm just concerned about my ec5's.
  • Rumdog
    • 6667
    I bet they'll stay cooler with your better cells. Give it a shot. Speed sounds about right to me.
    • jamespl
      • 748
      They are still just as hot with the 60c packs. I haven't checked the exact temp. I can hold onto them after a 5min run but they seem hot compared to everything else.
      • martin
        • 2881
        Get 6mm connectors that are much tighter when connected with more contact area + higher amp rating than the EC5
        • jamespl
          • 748
          I was thinking of upgrading. I was thinking 8mm. It's just a pain changing over all my packs.
          • Rumdog
            • 6667
            I've never used ec5's. I run 5.5mm bullets on all battery connectors. Even on 10s boats. Motor to battery, sometimes 8mm, but normally 5.5mm. Double check your soldering job as well.
            • martin
              • 2881
              Yes i use 6mm & 8mm, the 8mm are unbelievably tight & need plugging in & undoing a numder of times before you use them just to get them freed off a bit but their still tight though. Did the Turnigy motor come with 5mm or 6mm bullets.
              • jamespl
                • 748
                Only 4mm. Will be upgrading those too. Strangely they don't seem to get as hot as the battery connectors, they still get pretty hot though.
                • Prop-a-Gator
                  • Feb 2012
                  • 168
                  Wouldn't the higher C packs allow the motor to pull more amps = more heat & speed?
                  Even then, 5.5mm bullets should be ok on the batteries - at least yours doesn't seem like a mega-amp setup. I've never used ec5, so i don't know how they compare. I'd go with bigger ones on the motor to ESC connectors just because I seldom disconnect them. I've been planning to convert mine to 8mm, but have been lazy. They are 6mm now.
                  Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
