The final part of the strut of my tenshock mono became so hot after 1 second only of middle throttle...
The heat is so high: there's a dilatation and the axle come out a little...
I can fell some vibrations too on the strut (axle cover with the 2 ball bearings inside)...
I know i have a so hard configuration (5100kv@3S) but i think there's something wrong...
I've tried using grease or oil and the peak amp is always around 25A..!!!
Only 5A with motor disconnected from flex...
Here's the pic:
Here's the pic:
Same set-up as Ten Shock Samurai, you have either misalignment in the machined part or faulty bearings, spin the bearings and check for problem, also it is common that on the Ten Shock flexcable, the point where the cable enters the stub shaft is not trued, I have several spare ones for my boats and not every one is trued, but I run lower KV motor and don't have vibration , it will become apparent as RPM increases.
I will never catch up with some of you guys! I am lucky that I can cut the cable w/o cutting my fingers!
