Geneis esc question
  • pappystoys
    • May 2012
    • 13
    Geneis esc question
    Im running my genesis with a leo 4082 1600kv and I'm running two 3 cell zippy 5000. My esc is the seaking 180 amp and its acting up on me. What should be my next esc?
  • LOVE6S
    • May 2012
    • 521
    How is it acting up on you? Is it getting too hot and what do you use for a bec, the one with the esc, or a stand alone one? You may try to lower the low voltage cutoff, I use the turnigy 180 and they work pretty good, its the same esc. If it is still working you may want to try these two things first. If you want to just get a new esc I would probally get a swordfish 240 amp, but it is 260.00, you might be able to work the bugs out of yours.
    • pappystoys
      • May 2012
      • 13
      no its not getting to hot at all. It starts blinking and takes off some times and its hard to get the trim tab set between forward & reverse. Should a add a bed and lower my cutoff voltage?
      • 1945dave
        • Mar 2012
        • 265
        Hey Pappy, are you saying you programmed your ESC to include reverse? Not normally a good idea with flex cable setups. It causes problems unwinding the cable twist. Just the same I have the same esc as you and don't think the bec is your problem. Perhaps resetting the full throttle set position and then idle stop position manually not using the program card. Turn off the reverse ability then see how you like it.
        Dave
