exactly correct
lipos
I have been @ this for weeks now and I still don't know crap.....lol. I won't claim to know anything untill I have used them with out toasting anything. House included:D ...Jk..that was a poor attempt @ humeri basically went from a lipo newb to almost completely understanding them in about one day
So if I understand all this, for my SuperVee 27 I could buy two 14.8V 4000mah 145 44 23 380g 10C/12C Lipo batteries and run them in parallel. Would I then have a 20C max continous discharge on a 8000mah total or a 10C max continous discharge on a 8000mah battery? Would I also need a low voltage cut-off and a cell balancer? Also could I charge these batteries on my Super Brain 898 charger? It is claimed to be able to charge 1 to 8 cell lithium ion/lithium polymer batteries.
Thanks, Jamie
20C on parallel or 80 amps
Low Voltage Cuttoff is always a good idea, however, 8000mah should run a SV27 for 12 mins even at 70% battery capacity usage.
Balancer always needed
I have never seen this charger, looks like it can do the job
NO... this isn't correct....Originally posted by Fast Guy View PostSo if I understand all this, for my SuperVee 27 I could buy two 14.8V 4000mah 145 44 23 380g 10C/12C Lipo batteries and run them in parallel.
The SV27 is designed to run 2 6-cell packs in series... The wiring on the ESC is essentially identical to OSE's Y-Harness setup...
You want to get two 7.4V packs of whatever mah and whatever paralleling you like, and then run them in series on the SV27...
In other words... or in LIPO speak... the SV27 is designed to have one 2S pack connected to each of the two factory connectors... This wires the packs in series...
At each connector, you can parallel the packs as much as you like...
So, if you want lots of runtime, you'd buy a pair of 2S2P packs of 8000 or 10,000 or ??? mah and plug them in...
If you pluged in a pair of 14.8V lipos, like you suggested in your post... You'd fry the ESC in a hurry...Darin E. Jordan - Renton, WA
2-14.8V packs in parallel is 14.8V Yes, the wiring needs to be changed, your correct. Sorry about that one.
I'll get my boat out today and look into this.
Darin is probably giving the best advice if your not advanced at this, my fault.
thanks,
SteveLast edited by sjslhill; 04-15-2007, 09:21 AM.
Steve,Originally posted by Battlepack View Post2-14.8V packs in parallel is 14.8V Yes, the wiring needs to be changed, your correct. Sorry about that one.
thanks,
Steve
I think it would just take a quick wiring change to make a single 14.8V pack work... If you look at one of OSE's Y-Harnesses, that's how the stock ESC is wired... I think if you took out the wire in-between the two connectors, then removed one of the connectors and connected the loose wire to the remaining connector, you'd have it set up for a single pack arrangement and you could use a saddle setup of 14.8V cells paralleled together...Darin E. Jordan - Renton, WA
Thanks guys. I should of mentioned that the wiring to the ESC would have to be modified to eliminate the series connection. That could have caused a disaster as you noted for those that don't completely under stand the electrical side. I will have to be more detailed in my posts in the future. To me running the batteries in parallel means connecting them to the ESC in parallel also.Originally posted by Darin Jordan View PostIf you pluged in a pair of 14.8V lipos, like you suggested in your post... You'd fry the ESC in a hurry...
Running this configuration in my SuperVee with the Lipo batteries from BattlePacks site seemed good to me as I was getting the required 20C, low cost and a 8000mah run time to boot.
Would two 7.4V 4000mah 145 44 14 200g 10C/12C from your site in series be OK for the SuperVee? How would they compare to the IB 4200's for performance, run time and their expected life time.Originally posted by Battlepack View PostIt is a good idea if the wiring is correct. You do not need 20C type packs to run in a SV27, the low costs ones will work well.
thanks,
Steve
Thanks, Jamie
Yes.....but
You have to get a LVC and can't run it that long. The IB4200's would most likly outrun the 4000 LiPos.
Woops, forgot the life time. IB4200's, can't stand them myself, 25% failure rate on these cells. 4000mah LiPoly, if you use the LVC and keep the temp down to 110 or less, I'd guess several runs and much longer than NIMH cells.
This is all new however and I don't want to mislead anyone. Several are trying it, Joey did it with 2 7.4V3600 packs, Tom just ordered some packs as well. Another person ordered 4. We will see where this all ends up. I ordered a SV27 from OSE as well to do testing. Tom has a DPR to give us info back and I'll add one as well.
thanks,
Steve
Originally posted by Fast Guy View PostWould two 7.4V 4000mah 145 44 14 200g 10C/12C from your site in series be OK for the SuperVee? How would they compare to the IB 4200's for performance, run time and their expected life time.
Thanks, JamieLast edited by sjslhill; 04-15-2007, 12:45 PM.
In order to switch the stock SV esc to a parallel setup(for14.8) you would have to unsolder from the deans and go with +to+ and -to-. Then a resolder would have to be done for series running....I will be buying another esc...that would be a PIA in the field.
