Fighter Cat 8S 300 Amp ESC
  • mtbenjamin77
    • 885
    Anyone have any experience with these ESC's. What is the 4 wire connector for? Data logger maybe? Programming box? These ESC's seem to be awesome except they have no instructions what so ever. That's the only downfall I've found.
  • b20btec
    Senior
    • Aug 2011
    • 252
    It should come with a pink instruction sheet. The FC ESC is very easy to use, especially with the programmer. Leave the 4 Wire connector alone, it isn't for the consumer. If you haven't purchase the handheld programmer it'll be a good investment and makes life easier, works with all fightercat esc. I have 3 FC ESC and they perform very well.
    • mtbenjamin77
      • 885
      yeah my friend here in town has the programmer. I build and repair his boats so he lets me use his programmer no problem.
      • Make-a-Wake
        FE Rules!
        • 6057
        I ran one with the BEC and it smoked, the amperage output of it is not enough for a high torque servo acoording to Ben. He sent me a new 200a 16s as a replacement. Run an RX pack.
        • mtbenjamin77
          • 885
          Yes I have an RX batt tray already built in. 6V 1600 mah I'm running one HV 130oz metal gear low profile servo. But thinking of adding a second rudder and servo for a dual steering setup. so def. need the Rx batt. So to use the Rx battery I just remove the + lead on the ESC Rx wire?
          • Make-a-Wake
            FE Rules!
            • 6057
            Yep, the center lead.
            • carlcisneros
              • Jan 2010
              • 1237
              ESC Programming using the Program Box.doc
              The 4 wire plug is for Firmware updating only.
              and above all, get the program box.
              Above are the instructions I originally did for Ben.
              MAKE SURE AND DO THE PROGRAMMING WITH A 3S PACK. (THINGS will warm up
              very quickly is you use higher voltages for programming.) Just a safety thing is all folks.
              they are available in German and also Italian and I believe in French as well.
              • gettinbrushless
                • 154
                where can u buy the fighter cat esc's???????
                • carlcisneros
                  • Jan 2010
                  • 1237
                  they only ones available from FC Racing are the low voltage ESC's now.
