what effects timing has??
  • limitedr1
    • Aug 2011
    • 91
    So I got esc and programer in from ose so my Genesis finally got wet for the first time tonight. And frankly was kinda disappointed....I know the 20c rating is probably a big problem but I was still expecting more. I noticed on the programming card for my seaking 180 that the last value was timing? I have no idea what to put it at nor the affects it has if any on speed. I also noticed there was no difference in speed between 3/4 throttle and full.....anyone have an idea where I should have my timing set at for a 1250kv Leo on six cells? Any advice is much appreciated !
    I assume that your motor is a 4082/2.5Y. This motor will run well with 10-15* timing advance depending on the load, but the timing will usually not make a large difference in speed. What prop are you running? Typically the difference in speed between 3/4 and full throttle is not a lot in many sport setups. You are correct, all the power in an FE boat is in the packs, cheap low-C packs do not equal top speeds.
    • limitedr1
      • Aug 2011
      • 91
      Hey fluid. Dude I wish I could tell you what motor exactly. All I was told when I bought the boat was it was a 4082 1250kv. As for the prop again all I could do is take apic of it. I jack crap about props. I will go take the prop nut off and post the numbers.
      • limitedr1
        • Aug 2011
        • 91
        Ok it is a octura x445...I also have a grim racer 42x 55. Both are metal props. I also have a couple plastic ones that say k40 and k42 whatever that means
          The x445 should be good for around 45 mph with good packs and a well-trimmed boat. But it is pretty small for that motor and a 6S setup; that 42x55 is really small as are the plastic props. This explains why your speeds don't increase the last 1/4 throttle - the motor is wound out without enough load. Once you get some better packs you can move up to a larger prop and much more speed. Trimmed correctly with enough 'juice' that motor should spin an Octura x648 or Prather 230.
          • limitedr1
            • Aug 2011
            • 91
            fluid. Thanks man! Which of those two props is the smaller of the two? Do I run a risk of over heating using the smaller of the two now? Maybe I'll put that x445 on my k.o.s. It could do with a little more prop.
            • limitedr1
              • Aug 2011
              • 91
              Timing was set at 11.25°
              • limitedr1
                • Aug 2011
                • 91
                Well I'm gonna try a x642 instead of the x445. A tad smaller dia. But a tad more total pitch. Will GPS if the freak in wind ever stops blowing. Idaho and boats don't mix very often! Lol count to think of it that's why I gave up helis
