AS TITLED
. Great test this evening I am more than pleased. I will do this by the numbers. There is not screan shot software on my PC so I will list the DPR data.
Run 1 Setup:
KB8L graupner K40 HM200 esc Polly EX 4s-2P 30c 3300.
Run time 4 minutes
Charge: 5324mah (thats - the 30 seconds for the temp run)
Battery EEfficiency: 80%
Max Amps: 120.10
Max Voltage 16.34
Low Voltage 14.70
Max temp ESC 120
Max Watts 1624.13
Max temp motor 119 was 92 It did get up to 135 a few minutes after it came out of the water. I gues it was the lack of cooling once out.
=Max MPH 46.1=
Watts Average across both runs 392
The temps by the gun where almost 10 degrees higher on the motor. Bothe sets of packs where in the 130s. The numbers are just about the same for the 2s-1p 5000mah packs I ran in series. The handleing has to be tuned again. There is more weight up front now. I was starting to get it by the middle of the second run. The bows have to be set in order for it to bite and turn now. I think this is due to the extra 8mph I have picked up. With a good metal prop 50mph may be right around the cornner
The first clip is on the set of 2s-1p 5000s The second is the 4s-2p 3300s but I miss labled the intro. They are uploaing now. Give me about 20 minutes for the first one and about 40 for the second.
Video 1 4s packs
Clip 2 2s- packs
. Great test this evening I am more than pleased. I will do this by the numbers. There is not screan shot software on my PC so I will list the DPR data.Run 1 Setup:
Run time 4 minutes
Max Amps: 120.10
Max Voltage 16.34
Low Voltage 14.70
Max temp ESC 120
Max Watts 1624.13
=Max MPH 46.1=
The first clip is on the set of 2s-1p 5000s The second is the 4s-2p 3300s but I miss labled the intro. They are uploaing now. Give me about 20 minutes for the first one and about 40 for the second.Video 1 4s packs
Clip 2 2s- packs
. I am learning how to drive it all over again. You will see in clip 2 I am growing a bigger set....lol
