" Y " fittings for single cooling line
  • wht73
    • Feb 2012
    • 113
    Will installing y fittings in a single cooling line net any difference in temperature ?
    I would think that you would have to add an outlet to see any change.
    Any thoughts would be appreciated.
    Chris
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    When you add a Y the flow will go mostly to the device with the least resistance (usually the speed control) and reduce the flow to the path of most resistance (usually the motor). Is this what you want ? The only way to reliably increase flow is to install dual independant pickups - there are several ways to do this. Keep in mind that watercooling is, at best, a band-aid. A proper setup that doesn't create excessive heat is the first line of defense.
    • wht73
      • Feb 2012
      • 113
      I hear ya.
      I was running my new boat with one of my esc's I have and I'm not sure of the capacity. So after 6.5 min or run time when I shot the caps (2) on it it was 133 degr mtr was 105.
      I should be getting the stock esc back which is 60amps all might be well.
      It is all stock set up 1800kv/ stock SS pb prop ,14.8v/ 4s2p batts. The batteries might be on thelow end tho @ 30/40c.
      • properchopper
        • 6958
        Originally posted by wht73 View Post
        I hear ya.
        If after 6.5 minutes of running your motor was 105F, you're doing great. To reduce the load (and heat) on the caps, just add an additional cap or two like these : http://www.offshoreelectrics.com/pro...k-cap-35v-1000
        • Chilli
          • 3067
          The caps will oftern run little hotter than the body of the ESC. In the 130's is not a bad temp for the caps. Make sure you use good quality batteries to reduce ripple current and keep your caps happy.
          Mike Chirillo
          www.capitolrcmodelboats.com
          • keithbradley
            • 3663
            To add to what the other guys said, consider that the caps aren't water cooled themselves, although heat dissapation may play a small part.
            www.keithbradleyboats.com
