MHZ Lizard Extreme---motor, hardware, etc.,suggestions
  • Flying Scotsman
    Fast Electric Adict!
    • 5190
    The motor is up to your goals and hardware...prop etc....also make a wood backing to the transom.
    Douggie
      • 5660
      Thanks Douggie, I can't seem to find the diameter of the can for the Neu 1515,i have a Peter Z motor mount that is good for 40mm dia. A Leo 4082 would work, but liked Tony's recommendation of the 1515. I want to have transom reinforcement, thanks for pointing it out, toying with different ideas on materials.
      • ozzie-crawl
        • Sep 2008
        • 2865
        Think the 1500 series are 1.53" or 38.862mm
          • 5660
          Thanks, for some reason one can only see the length of the can on the Neu Motor Chart, but not the diameter. Appreciate the info!
          • properchopper
            rcgoatbuild@snotmail.com
            • 6958
            If you go with the 1515 1Y there's a few choices : Neu 1515 1Y 2200 KV ; Castle Neu 1515 1Y 2200 KV ; Leo 4074 2150 0r 2200 KV. A t-180 will work fine for these (might put more caps on it for insurance) A simple nose-mount motor mount will work.
              • 5660
              Thanks, Tony!
              I am not ruling out these nose-mount motor mount. I guess I am just fancying a mount with extended stringers. I was thinking CF rails but first of all don't know where to get CF boards and also worried about cutting them neatly, don't want to go with ply-wood at this moment. Maybe I am just over the top and out of my mind, but I like to take my time to think these things before diving into the build. I have some FG "prototyping Board" the same one used on printed circuit board w/o the copper foil. Only thing is that it comes pre-drilled with lots of small holes. Thinking actully using this as transom doubler. It is quite stiff. Anyway, please excuse me for being long-winded.
              • properchopper
                • 6958
                Thanks, Tony!
                One thing I've found is that a "softer" material for a transom doubler (like 3/32 " ply) will conform to the transom better without gaps like with really rigid material - problem is that if you tighten the hardware a little too much the boat hull collapses against the rigid doubler and can crack if there's a gap between the doubler and the transom.
                • properchopper
                  • 6958
                  Thanks, Tony!
                    • 5660
                    Wow! Thanks again for taking the time ! I am absorbing these knowledge and am very grateful!
                    • properchopper
                      • 6958
                      Originally posted by ozzie-crawl View Post
                      Yep first time you take a drill to a new hull is a bit of a nervous moment. I mask the transom area then mark out were each part goes then measure about 10 times to make sure its rite lol. You can also double sided tape the stinger/trim tabs/ turn fins/rudder in place to work out were you want to place every thing and make sure it all fits well.
                      Excellent advice. By laying out the hardware on the transom (sticky tape them on) you can plan the locations and avoid the dreaded real estate conflict between the trim tab on the right and the rudder bracket (picture on request). Remember that the LE is an extreme deep V so mount the stinger (or strut) with the propshaft center at least 3/8" up to let the hull settle and minimize chine walk. Get yourself one of these to mark your holes : http://www3.towerhobbies.com/cgi-bin...k378&search=Go
                      After you mark the hole location, drill through the tape ( I put a drop of oil on the drill bit to prevent chipping the gelcoat).
                      Anxious to see this build go forward !
                      Here's how the Dead Center Hole Locater works :
                        • 5660
                        Thanks Tony, I appreciate you taking the time to walk me thru these steps.
                        This is the exact info I am craving for!
                        I have another two weeks of work that will prevent me from really starting. I will post progress once I start.
                        • properchopper
                          • 6958
                          Be glad to walk you step by step ; I always wanted to build one of these; never got the chance ! ( are you in the L.A. area ? - I'm in Torrance)
                          • JIM MARCUM
                            • Jun 2011
                            • 770
                            Tony, you need to get back to work on your boats for the Nationals in 12 days So much to do, so little time...................JIM
                            JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                            • properchopper
                              • 6958
                              Mine is completely filled out and tested/verified . How's yours doing ?
                              template nats setup.pdf
                                • 5660
                                Tony, for me that will be an absolute honor, I know you guys have a big event coming , next week if i remember. I won't be ready anyway, if when the time comes I could shoot you a PM. I live near Pasadena. I could not respond this morning --something wrong with my phone. Wanted to thank you since I saw your message.
