Fighter cat 3-16s 200 amp motor controller programming box issues
  • tryinotocrash
    • May 2012
    • 190
    Hello. Not sure where else to ask for more help so here goes. I bought this ESC and it works but I need to program it for my setup. So I bought the fighter cat programming box. Then I watched the U tube video on how to use the programmer. When I connect everything as instructed all I get is a row of black boxes on the programmer. Has anyone run into this? I am powering it with 4 1.5 volt batteries in a flight pack. It runs in the boat but I can't get it to program. I just bought this and it arrived today, however there is no phone number to call and I sent an e-mail last week to see if there was a way to program manually but got no response.. Any help?
    Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    For starters you need to use a 3s lipo not 41.5 volts pluged into the controller. You need to plug a reciever battery into the programing box and have the controller hooked up to a motor. When it turns on it will want to know what controller you have so you scroll through and pick boat controller HV. It may say a 16 cell count but I dont remember. Then you can scroll through the menu and pick what you want. Everytime you pick something it will beep. If it doesn't then something is not right. Try that and see if it works.
    Mark
    • tryinotocrash
      • May 2012
      • 190
      oh sorry that is four 1.5 volt batteries :-) and a three cell.. will try to hook it to the motor..
      • carlcisneros
        • Jan 2010
        • 1218
        here ya go.
        ESC Programming using the Program Box.
        Thank you for purchasing the Fightercat Racing Electronic Speed Controller.
        Failure to follow the directions for programming may result in injury to yourself and damage to the ESC itself. We highly suggest that you read and follow the instructions carefully when programming the ESC prior to first using the device. Fightercat Racing is not responsible for you’re misuse of the product or any damage caused while using the device. Fightercat Racing does not take responsibility for and injury/damage from the modification/misuse of any of the company’s products. Fightercat Racing has the right to change the design, features, functions and operating requirements of our products without any advanced notice.
        HIGH VOLTAGE ESC FEATURES
        Designed for Boat/Ducted Fan/Car use
        Voltage from 6-52V (lower on the low voltage models)
        Easily programmable using the Program Box or Laptop via USB cable and FighterCat Software.
        NiCad/NiMH/LiFe/LiOn/LiPo battery compatible
        Low Voltage cut off programmable
        Timing adjustable in one (1) degree increments
        Three (3) types of Throttle curves available
        Reverse can be turned off or can be set up for special usage
        Auto cut off of power is signal is lost for 3 seconds
        Auto detect of throttle can be set
        Motor power (forward/Reverse) can be set
        Reverse function (if used) delay can be set
        FACTORY SET DEFAULT VALUES
        REVERSE: OFF
        TIMING: 0 DEGREES
        FREQUENCY: 8KHZ
        ACCELERATION: MEDIUM
        BATTERY TYPE: LI-ION/LIPO
        NICAD/NIMH CUT OFF: 0.05V
        NUMBER OF CELLS: AUTO DETECT
        LI-ION/LIPO CUT OFF: 3.0V
        LIFE CUT OFF: 2.5V
        INITIALIZE POINT: AUTO
        END POINT: AUTO
        THROTTLE CURVE: LINEAR
        POWER LIMIT FORWARD: OFF
        POWER LIMIT REVERSE: OFF
        START UP DELAY TIME: .25 SECONDS
        PROGRAMMING USING THE PROGRAM BOX
        NOTE: The ESC and Motor must be connected together before hooking up the
        Program Box.
        NOTE: If your particular ESC HAS a built in BEC (low voltage models), you do NOT need to use a separate receiver battery for power.
        1. Locate the 2 plug receivers on the side of the program box.
        2. One is for the ESC plug (+ - and signal(shown with a small square wave )), the
        other one is for battery supply voltage. (typically 6 volts).
        3. Plug the ESC’s receiver plug into the 3 prong receiver on the program box.
        4. Plug a 6 volt receiver battery into the other 2 prong receiver plug on the program box.
        5. Now plug the supply battery up to the ESC and you should hear a beep letting
        you know that it is ready for programming.
        NOTE: If you do not hear a beep, go back and make sure all connections have been made correctly.
        6. Once everything is hooked up correctly and you get the beep you can start the programming.
        NOTE: Every time you make a selection, you will hear a BEEP. This is to let you know that the ESC has memorized what ever it is you selected.
        7. The first display with be the company name. It will only last a few seconds.
        8. Model select is next: Airplane, Heli, Boat, Car
        9. ESC Type: Normal, 16S HV, 20S HV
        10. Reverse: ON/OFF
        11. Timing: chose the timing you need for the motor you are running. (VERY IMPORTANT)
        12. Frequency: Chose the frequency you need for the motor you are running that the maker wants the motor to run. (typically 8KHZ)
        13. Acceleration: Soft, Medium, Hard
        14. Battery type (Accumulator)
        15. Number of Cells: Auto or the actual number of cells you are running.
        16. LiPo cut off voltage
        17. Cut off type: Slow Down or Hard
        18. Throttle Curve: Linear/Logarithmic/Exponential
        19. Power Limit Forward
        20. Power Limit Reverse (if you selected REVERSE OFF above, then this will not be able to be set.)
        21. Throttle Delay
        22. Forward point: Auto or select any of the amounts needed.
        23. Reverse point: Auto or select any of the amounts needed. (when reverse is OFF, you will not be able to select any values for this.)
        24. Timing Monitor: On or Off
        After the last programming item has been finished, disconnect the ESC supply battery and you are finished programming your Fightercat ESC.
        The last programming selections you have just made will be memorized in the Program Box so the nest time you hook it up to the ESC that information will still be there.
        NOTE: It would be a good idea to get hold of a 3S pack and use THAT for the first time or 2 that you try to program the ESC with for practice purposes. It is all about becoming familiar with the products you are using to prevent any problems and gaining experience in programming using a new company’s equipment.
        Once you become familiar with programming using the Programming Box, it will take only about 15 seconds or so to program an ESC once it is hooked up.
        • monojeff
          • Nov 2010
          • 2551
          Fightercat was and is in the process of moving his shop.
          If u need to get ahold of him then you can email him but it may take a bit for him to respond as he is catching up on emails and orders.
          Follow the directions posted and u should be good to go.
          Make sure u program the esc to the correct timing of the motor to assure optimal performance don't fry anything doing it incorrectly.
          Good luck and have fun.
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • tryinotocrash
            • May 2012
            • 190
            got a reply from Fightercat and he is sending me another programmer. I made sure to follow directions but there seems to be an issue. Will see what happens next. Thanks for the replies with help.
            • boddenboys4
              • Jan 2012
              • 89
              3- 20s - 100A FC ESC. I had the same trouble with the box and I'm using a receiver pack, should I use a 3s pack instead then? I have programmed a 2-8s - 240A FC ESC no problem but that has power from the BEC.
              Also I've been trying to program using the USB link but whenever I click on connect to ESC, the motor wont beep so its actually not connecting to the ESC. What is the power supply if the plug is being used already in the USB link?
              • Rumdog
                • 6453
                Flip the plug up side down going into the prog. box. Trust me, I had the same thing going on. After scratching my head hard enough, I tried it. Up side down, meaning the opposite of how you'd plug into your reciever.
                • tryinotocrash
                  • May 2012
                  • 190
                  Really? I never tried that. I got the other box but still get no beeps when I program. Guess I will give that a shot too and see what happens. Does Ben know about that? He said that would ruin the program box?? Not doubting you just saying.
                  • boddenboys4
                    • Jan 2012
                    • 89
                    Well I'm going to try it and let you know.
                    • boddenboys4
                      • Jan 2012
                      • 89
                      Ok that didn't work either! How do I power the ESC when using the USB link to program it?
                      • carlcisneros
                        • Jan 2010
                        • 1218
                        when using the computer to program the ESC you STILL NEED to hook up a 3Spack to the ESC as well
                        as have the motor hooked up to the ESC as well. Ya got to hear them BEEPS.
                        • boddenboys4
                          • Jan 2012
                          • 89
                          Which plug do you use for the battery to power the ESC, the plug with 3 pins is what is used to plug into the USB link, there's another plug with 4 pins, is it that one? If so where do I get a plug for that one?
                          • carlcisneros
                            • Jan 2010
                            • 1218
                            FighterCat ESC Instructions (latest version).doc
                            the 4 pin plug is used for firmware upgrade only................. do NOT mess with it,
                            the 2 big black (-) andred (+) wires are for esc power.
                            you need a 3S lipo battery for programming purposes for powering the esc..
                            please read the fightercat programming instructions completely before hooking any thing up to
                            your laptop.
                            • boddenboys4
                              • Jan 2012
                              • 89
                              I hook up the 3s lipo to the big battery leads into the ESC but it's not powering up when trying to program. Right now if it's hooked up to the receiver as you touch the throttle it is full. How can it be rectified?
