HET Typhoon EDF engine
  • znus
    Broke, as usual
    • Jun 2011
    • 120
    Yes, I did the search but not that much showed up. Might be because it's aimed for EDF-duty
    Thinking of putting something more unusual in my newly acquired RCMK Flying Cat. I've run the Leopards and Turnigys (3674, 4074, 4082, 5682 and 5692), can't justify the cost of Neu's and why not plant a HET Typhoon 700-98 670 or 780kv in the middle of the cat, run it on 12s and see what happens? It should be able to get things going pretty well? If I remember correctly 6BOOST had a magical moment when trying out his Turnigy 3994 850kv and this s*cker is even bigger!
    Its huge - 39 x 98 mm (thats 1,54" x 3.9"), 8 mm shaft, 4-pole, the EDF guys seems to like it, it handles 2400 watts & 4800 burst, it fits under the hatch and I can use Neu/CC's waterjackets. It also is $150, which is half of what closest comparable Neu (1527) will fetch.
    Any opinions?
    25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
  • lars_01
    • 128
    Maybe this will make you a little less broke!:)http://www.hobbyking.com/hobbyking/s...20mm_EDF_.html
    111
    • znus
      Broke, as usual
      • Jun 2011
      • 120
      Too high kv for 12s, otherwise I would've bought it a loooong time ago
      • znus
        Broke, as usual
        • Jun 2011
        • 120
        Well, just ordered a 780 kv 700-98 and I'm gonna run it in my Flying Cat. This will be interesting.
