rudder lenth (df26) and general guidelines
  • dana
    • Mar 2010
    • 3660
    i hate the cheap rudder i got for my df26. its just not great quality, but also im curious if my rudder is causing more harm than good. its a 3' rudder form bottom of bracket to tip. is this too long? i was looking at the speedmaster mini rudder, which says 4", but the quality is much better than what i have now. any thoughts? suggestions? heres a crappy video, i didnt catch much of the turning because im still messing with my video camera/hat contraption, but you can hear the prop jumping in and out of the water. thanks guys
  • dana
    • Mar 2010
    • 3660
    C'mon nobody's got any advise here? I'm ready to buy a rudder. Should I go longer or shorter?
    • runzwithsizorz
      • Jan 2009
      • 901
      http://forums.offshoreelectrics.com/...r-relationship
        I've been lucky cutting mine down(haven't gone too far).Take two rudders,cut one down a 1/4 at a time and test,repeat till you start to lose the desired steering.Then leave the second one a 1/4" longer and you should be fine.You could use this one you don't like to experiment with.Unless you are going to change the width drastically with the new one. Does that little 26" carve like a DF should?
        • dana
          • Mar 2010
          • 3660
          Well, I can say that it turns ok. Not great IMO. The tolerances on the current rudder aren't good. Lots of play in there. Cutting the crappy one for testing is a good idea. If you watch my video, you can hear the prop. Should give a good idea what's going on. I noticed the new revolt has a short rudder I think. Got me thinking....
            I took quite a bit off my rudder for my cat.You can run a broader blade for more effective area and turn down your Expo on the TX.
            • dana
              • Mar 2010
              • 3660
              It seems like there's a serious lack of quality 3" rudders. 4" and up they're well built and nice, anything smaller and it's crap
                This is an example of that quality,the small inlets are unacceptable to me.The bracketry is interchangeable on these.Just a matter of who ordered them and for what $
                Maybe get the 4" and cut it down to the desired 3"
                  Grab one of these and cut it to the water pickup.Then you will have a 3" blade. http://www.offshoreelectrics.com/pro...prod=ose-80050
                  I have a couple of these so I measured it.
                  • dana
                    • Mar 2010
                    • 3660
                    Thanks for the help man...
                    • dana
                      • Mar 2010
                      • 3660
                      i ended up grabbing the speedmaster mini. was pricey compared to the $15 rudder i had, and believe me, the quality is wayyy better! had to cut the mount a bit cause the footprint is too large for the little df, but its on there. test tomorrow
                        Can't wait to see the results
                        • dana
                          • Mar 2010
                          • 3660
                          The new rudder worked nicely. Seemed much more stable... Not sure if the play in the old one was causing some of the squirrel like behavior, but I'm very happy with the new one. It's nice living 20 minutes from ose, I get my stuff really quickly in the mail
