Proboat 1500kv on 5s
  • ozzie-crawl
    • Sep 2008
    • 2943
    Building a 34" cat (32" with 2" extension) and looking at running 2x 1500kv proboat motors on 5s turning m442s.
    Cat is fairly large for a 34" being 14" wide. (similar dimensions to a sprint cat)
    Looking for mid to upper 40s for 3-4 minutes if possible.
    Would the turnigy 120a be ok for this setup ?
    Any thoughts suggestions welcome.
  • Make-a-Wake
    FE Rules!
    • 6057
    The T120 would be more than up to the task if you are going to run one for each motor....................right? Should hit 50 mph+
      • 9481
      Tagin along on this one!
      • ozzie-crawl
        • Sep 2008
        • 2943
        Yep definitely running 2 esc,s.
        I have a brand new t180 but its fairly large (do have room enough for 2 in hull) thinking 2x t120s will take a lot less room and save a little weight
        • ozzie-crawl
          • Sep 2008
          • 2943
          Just thought i would place the 180 in the hull and size it up. Plenty of room.
          I thought Fluid once said something about using to big a speedy. Something to do with higher resistance. Could have this confused with something else as its been a couple years since i played with boats.
          • Make-a-Wake
            FE Rules!
            • 6057
            T180's are overkill.....................the 120's are fine.
            • ozzie-crawl
              • Sep 2008
              • 2943
              Mite just sell the 180 and buy a couple 120s
              • Rumdog
                • 6667
                I like overkill. Plus if you decide to up the power in the future, you just need a motor swap and not motors plus esc's
