Stinger bushings to smal
  • ozzie-crawl
    • Sep 2008
    • 2943
    Brought two 3/16 stingers. both have bronze bushings but one is under size. its not 4mm as a 4.5mm drill bit will just push threw.
    What is best way to open it up ?
    Can i just buy a 3/16 drill bit and run threw it with out destroying the bushing. Or put some fine grade emery paper on a 4mm drill shaft and try hone it out a bit
  • Basstronics
    • 2384
    5mm and a 4.5mm will barely push thru?
    Ream is the best way. I had similar issue with a 1/8" strut. I bought a .001" over reamer. I used some Tap Magic and the ream and the hole came out real SMOOTH.
    Drills can be tricky. First off you wont get a real smooth surface with a drill. Also since its close to size it has a tendency to grab and rip the material- pulling it towards center.
    If you go forth with a drill clamp the strut down. However I would replace the bronze bearing in question. Its cheaper than a reamer.
    • ozzie-crawl
      • Sep 2008
      • 2943
      Mite be easier getting a new stinger by the sounds of it.
      • drwayne
        • 3012
        Gday
        3/16 is 4.78mm
        you'd need 4.85+ else seize !
        where from these stingers ?
        I know where they're going
        W
        • ozzie-crawl
          • Sep 2008
          • 2943
          Hey doc. I maybe able to remove bushings then locktite a piece of 1/4 brass tube in and then make my own brass bushing
