Medusa motors
Tags: None
I've been contemplating them for months now especially the new v2's 920 watts thats a horse and a quarter for hulls like the bj and sv and the 4 poles...Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
I was thinking about the 36-60-2000 KV as a substitute for the Feigao 8XL. It has a smaller can but more max amps.
I know a few heli guys that swear by them... I thought they were overpriced and
a bit weak to be honest...
If they really can put out 920 watts and have a high efficiency then they are better then the Chinese counter parts. If you get one please keep us posted, after all, there is a chance they are a hidden treasure.
:D:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
I was just checking the graph on their page and it claims it's between 87 and 91% efficient under 29 to 59 ampsSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Yes that is good. IMO that level of amp draw is found on mild setups like an SV or BJ26. So as a drop in replacement for one fo those boats it "may" be a good upgrade. If you are looking to run a hot setup that efficientcy curve is to low to do you any good.
Here's the graphAttached FilesSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
