up in smoke
  • HondaHead
    • Mar 2012
    • 15
    up in smoke
    whats up guys,had a little fire in my pro boat mystic,has a hobby king 180 amp ecs and a leopard 3674 motor running 2 sky lipo 3 cell 5000mah,
    was running at the local pond and everything was good plenty of water flowing and it just stopped and started smokeing,got it to shore and opened the
    hatch ecs melted and every thing torched also was running a grim 425x55 prop was i running to much of a setup for that ecs just curious,thanks for any
    help in advance
  • stadiumyamaha
    • 1371
    What is the kv of motor?
    • HondaHead
      • Mar 2012
      • 15
      1400kv,been running this set up for 2 weeks no probs at all till yesturday
      • maddmatt
        • Jun 2011
        • 250
        You probably have some type of resistance in the flex shaft or bushing causing a excessive load. Lube your shaft. Holding the trigger for 3 min. pinned? I've been beating the poop out of my t180, pulling some amps for sure at short burst and its working like a swiss watch. Thats a good esc. Do you have Extra caps which help? Decent batteries w/ good c rating?? Are you using a BEC or rx pack?? There are alot of factors. Buy new and try it again!! You shouldn't have a problem w/ that setup. IMO. Later, MM.
        • HondaHead
          • Mar 2012
          • 15
          everything is cleaned and lubed after each run flex shaft is centered in the tube and im running a bec and i have the extra caps
