I have a twin genesis that is currently running a pair of Chinese 3660 2700kv on 4S and am looking to upgrade the motors before they go bad. I was thinking a pair of leopard 3674 2200kv or 3674 2700kv for this setup? I am running 2 T180's with extra caps also. I want to run 4s..... Any ideas????
Twin Genesis motors?? 4074 2200kv what do you think?
Last edited by jasoncyclone; 04-28-2012, 11:18 PM.Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!Tags: None
Is there actually enough room in the hulls to have the 4074 with cooling jackets and accessible water cooling slots etc?
I think someone had one so it is possible, but yeah i remember something about it being really hard to remove the motors!
i think if youve got two 36 size motors in the hull it should be fine
If you do use those motors Don't forget to drop the timing down from the 15 degree default setting to 3 degrees or so.
Both those motors are D wind motors & won't like high timing. Although I think the 2700kv motor would really be the 2650 kv version.
Personally I'd go for the 2200kv version.See the danger. THEN DO IT ANYWAY!!!
Ivw been thinking of the 2200KV version. I havee a Geico running 4S on 2200KV and like it....Thanks for reminding me about the timing! I will make sure to lower the timing.Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
