X-Power 100A Esc Trouble
  • jpracing1997
    • Mar 2008
    • 661
    I bought this brand new esc from OSE yesterday and cant get it to do anything! Any suggestions, this thing wont arm or make any kind of sounds. It looks as if I got a bad esc! Any ideas welcome!!!!!!!!!!!!
  • Mich. Maniac
    • 1456
    It should come ready to fire pretty much. You need bec to rx in order to control them I think. They dont use bec inside
    • SJFE
      • 4867
      They are OPTO esc's. You need a receiver battery pluged into the receiver in order for it to work.
      • wamf
        • Mar 2008
        • 75
        You may already know this (I didn't ) but It's non bec. You have to connect a seperate battery to the rx or add a bec.
        MikeV
        • calcagno45
          • Mar 2008
          • 1050
          WOW 3 responses at the same time.
          And yes, they require a Rx pack of some type. Eventhough they have the red wire still in the tx reciever plug, it isn't sending power there. Plug a 5cell pack or 4 AA battieries in there and "Viola"
          Now if you a running the Rx pack already, then you may have a problem. If you bought it within the past couple of weeks, Steven should have included the PC link and the download. Try resetting the programming.
          • jpracing1997
            • Mar 2008
            • 661
            Dead
            Yes i have a battery powering the receiver and still nothing. I read the paperwork before I even tried it, but this thing is dead. It wont beep , the motor never turns alittle or nothing. What can I do?
            • Mich. Maniac
              • 1456
              What radio are you using and what channel is the esc in. Are you plugging it in backwards perhaps to the rx? I know your not dumb but all easy things to try. What battery are you using to power esc cause I think it has to be at least 7.2V.
              • Steven Vaccaro
                Administrator
                • 8932
                Sounds like throttle adjustment problem on the transmitter.
                First start out without the esc plugged into the RX. Turn on the radio.
                Does the rudder work?
                If yes than you have power to the RX.
                Now don't shut anything off! Without the motor batteries plugged in! Plug in the esc lead into the RX. Stand clear of the prop, now plug in the motor batteries.
                Does it beep? If not start adjusting the throttle adjustment on the TX. See if it finds it.
                Steven Vaccaro
                • OJ racer
                  • Dec 2007
                  • 179
                  I got one of those ESCs also, and it gave me no problems at all. I first ran it with one 8.4 volt 7 cell nimh, and it beeps before I even turn on the Rx, if I forget and plug it in first. no problems. But I do run with a reciever pack.
                  • jpracing1997
                    • Mar 2008
                    • 661
                    Doa
                    I tried everything as everyone has stated and it wont work. I know to plug in a receiver pack battery and followed the steps.
                    1. Plugged the motor to esc
                    2. Plugged the esc to receiver.
                    3. Then battery to receiver.
                    4. Then batteries to esc.
                    I done all this with another receiver and it works fine just not enough amps.
                    I am pretty sure this thing is dead!!!!!!!!!!!!!!!!!!!!!!
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      Please answer the above question?
                      Steven Vaccaro
                      • jpracing1997
                        • Mar 2008
                        • 661
                        Esc
                        No it wont work either!
                        • jpracing1997
                          • Mar 2008
                          • 661
                          I plugged the esc to the receiver and powered the esc and still nothing.
                          • Mich. Maniac
                            • 1456
                            then there is a problem with your receiver, radio, or receiver battery, if the servo wont work why would esc?
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              Mich is right. Check the power going to the receiver. If your dad has a volt meter check the voltage.
                              Steven Vaccaro
