Thanks Fluid, the dog gap is about 1/2 the thickness of the cable. I'll increase it some more. A thrust bearing is one item i should have got a while ago, i will try to eliminate as much excess wire as i can. Ive played with trim angle a little trying to make it run dryer, by a degree or two and found its best atm on approx 1/2 - 1 degree positive trim as you say.
Really apprecite you guys looking over my set up and giving me some needed advice. Before i place my order with OSE, for the motor and some bullets, thrust bearing, cable saver and larger props, is there anything else i may need?
I will be looking forward to posting the results, thanks.
