Boat Building supplies
  • liteumup69
    • May 2011
    • 145
    Hello all:
    I need some assistance in finding a very high quality flex shafts,and brass stuffing tube with teflon liner, they will be used in a cat, so I would need left/right rotation, also what is the perferd method for mounting the shaft to the drive dog..welding? or epoxy, Thanks for the help.
    Paul
  • 785boats
    Wet Track Racing
    • 3169
    You are already at one of the best places, right here on Offshore Electrics.
    Have a look through the whole shop, but here's a link to the driveline section.
    http://www.offshoreelectrics.com/pro...at=Flex+Cables
    • liteumup69
      • May 2011
      • 145
      Thanks!
      I have looked through everything on OSE, Kentic racing, Just wondering if there's one better than the other, I don't want to risk breaking a drive line do to quality issues
      • scott007
        • Feb 2012
        • 9
        Look at MHZ.
        • jasoncyclone
          • Jun 2011
          • 475
          I've never had any issues with OSE... They have great prices and very fast shipping.
          Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
          • jcald2000
            • 768
            The best flex shafts are the Hughy brand currently.
            • siberianhusky
              • Dec 2009
              • 2184
              And have been for a very long time! Factory assembled, just cut to length.
              I'd skip the teflon, adds drag as well as being a very weak link in the drive line, once it starts to wear little strings form, they can bind up the flex causing the drive line to grenade. Proper sized K&S brass tubing is all you need, brass makes an excellent bushing material. I still have a boat from the 80's running the original stuffing tube.
              Once the flex cable is under load it forms a spiral inside the stuffing tube and only makes contact in a couple areas at any time. All that extra contact area is just extra drag with the liner.
              • liteumup69
                • May 2011
                • 145
                Thanks all for the help, Siberian, you don't think I should use teflon? Won't it aid in keeping the drive line free of water, also do the offer just the flex shaft? I don't need the dog end, I have to weld it to mine.. Thanks Paul
