Hydra 120 programming info
  • JimClark
    • 5913
    Just got a Hydra 120 and was wondering if there are program settings I should not touch. The documentation on the programming seems to be lacking a little and I am dense anyway any suggestions would be appreciated. Most interested in the current limiter and the start power and the throttle curve.
    Jim Clark
    Billy Graham
  • RCprince
    • Jul 2007
    • 1684
    Wait the Hydras are reversible ?
    Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
    • JimClark
      • 5913
      That setting can also change to "forward to reverse" It says that this setting makes the boat operate freely in forward and reverse"
      Jim
      Billy Graham
      • Steven Vaccaro
        Administrator
        • 8932
        A little hidden secret. Ever wonder why? BOOM
        Steven Vaccaro
        • RandyatBBY
          • 3943
          The reverse is for the trigger throw incase you are programing a car setup. It is some of the genaric (sp) for the program to cover all models. I never use reverse in a boat it will cause beral and not what you want. You do want ti to fre spin, Also keep the soft start setting. The voltage cut off is important for Lipo 3V. per cell.
          Randy
          BBY Racing
          • JimClark
            • 5913
            Randy what about the current limiter and the throttle curve?
            Billy Graham
            • RandyatBBY
              • 3943
              I am not sure how the current limiter works I will be calling Joe Ford tomorrow I will ask.
              Throttle curve will make the trigger more responsive or less. I have tried to use the curve in this program. But it think it is better to use the radio curve so you can adjust in the field with the radio, I never take a lap top to the pond.
              Randy
              BBY Racing
              • RCprince
                • Jul 2007
                • 1684
                lol funny Steve..
                But are you in essence saying the barracuda is better for reverse...
                • RCprince
                  • Jul 2007
                  • 1684
                  Jim your missing one key factor, although CC says there esc is motor sensing...What kinda motor are you running.
                  • JimClark
                    • 5913
                    I don't plan on using the reverse function. Right now all I have is the SV27 motor a 6 pole and possibly in the future I might run again with ERCU so it would be a Himax 1500kv that is also a 6 pole motor
                    Jim
                    Billy Graham
