G10 fiberglass for rails in a mono?
  • Old Sloppy
    Harry from Atlanta
    • Jul 2007
    • 201
    Sorry for being so uninitiated: what is G10 and where can you get it? I have heard of it and when I was doing my build in July I was looking for it but couldn't find any, used ply wood instead. I would appreciate if someone doesn't mind the time to give a little info here to me.
    Thanks!
    G-10 is fiberglass that is molded into a flat plate, most times it is compression moulded, both sides are quite smooth. In my case the plate was 12" by 18" by 1/8" thick.
    Harry
    60" Expresscraft SuperCat
    (2) 2028 Castle motors 64.7 mph
    10s3p with x450/3 props
    15,000 mah 40c cells,
    • Old Sloppy
      Harry from Atlanta
      • Jul 2007
      • 201
      Originally posted by runzwithsizorz View Post
      You may also want to leave a hole back were the rail
      joins with the transome for drainage.
      The drainage is nice, I sometimes route my servo wires thru there, it makes the wiring look neat and tidy.
      Harry
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        Thanks!
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        • HOTWATER
          • 2419
          Tony....you beat me to it...lol!
          Mcmaster is THE place to go for all kinds of cool stuff....kinda brings the creativity out of you just looking at all of the neat things they have!
          Always very quick shipping from them...just like Steven does for us here at OSE....
          "Will race for cookies!"
          IMPBA D12
            Thank you Harry and Tony! Really appreciate your taking the time to point me the right place! Book marking this site right now!
            • detox
              • 2357
              IMO the G10 is overkill. Regular plywood is lots cheaper and strong enough to get the job done. Epoxy also bonds to plywood better.
              Although G10 does make a verygood ride pad surface on hydros...along with carbon fiber plate.
              • HOTWATER
                • 2419
                ......and works beautifully as servo mounting trays!! No worries about sealing it to waterproof it....good to go!
                IMPBA D12
                • HOTWATER
                  • 2419
                  ....bulkheads too...
                  IMPBA D12
                    I was using a Peter Z mount, wanted to make rails out of it, although at that time I thought G stands for graphite, some sort of hi-tech carbon fibre. I wanted to make something similar to this mount since I was also using the stuffing tube support.http://kintecracing.com/Pursuit.html Anyway, ply wood worked but it is good to know and see how the G 10 can be used. Thanks.
                    • KartRacer
                      • Aug 2012
                      • 363
                      Thanks for the link. Interesting product. I'll have to order some.
                      KartRacer ~ Dennis B
                      Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
                      • CanAmAB
                        • Apr 2012
                        • 29
                        Using a cheap wet tile saw such as one from harbor freight works well to keep the dust at a min. It's not good to breath fiberglass dust. I use the G10 and it is good stuff.
