Saltwater maintenance and advice?
  • oct6454
    • 3
    i a have a super vee 27 brushless and am looking forward to running it. I plan to use it on the saltwater. I have heard it is a bad idea but i live on the water so it is very convinient. I need to know what you guys would do to take care of the boat???????
  • andym
    More Go Than Show Prop Co
    • 2454
    Mate I do not think it is a bad idea, quite fun actualy. Maintanance is the same no matter where you run. Clean in fresh water, lube everything well and make sure you run some fresh through the cooling lines. Some protective spray like corrosion x on anything that can oxidise in the salt is also warranted. Have fun and look after your boat and it will last for years.
    • DISAR
      • 1137
      I run my SV27 and other boats in sea water without any problems (Only problem is that the SV27 does not handle very well even in slight waves). What I do is:
      a) Run fresh water in cooling lines as soon as you finished
      b) Wash with fresh water the hull outside
      c) Remove flex shaft clean with corrosion protection spray and grease
      d) I also put some grease on the bolts
      http://www.rcfastboats.com/
      • Ocean Racer
        • 511
        The main thing you have to do is clean it and dont flip it and you will have a blast. If i can find the thread ill put a link in here its all about what you are going to do.
        Failure is the First step to SUCCESS
        • Ocean Racer
          • 511
          Ok i just found it took me a while but i got it
