i am building a 48 1/2 inch exceed hydro leopard 5692 1000 kv motor fightercat 300 esc and motor mount esc is good for 16s lipo power. i still have the 76 mm stock gas prop looking for ideas from you fine people to help finish it off any ideas would be appreciated as this is a learning process for me and lotsa fun.
& knows more about FE than 99% of the OSE followers. But, in this case I disagree about NOT using the 5692 1000KV Leopard motor you already have. Running 8S2P (8 cell LIPO, 2 packs) (29.6V) is within its rated max voltage of 30 volts. You might consider 6S2P to start off - you can always add more two 2S LIPOS in series later. As to props, I'd start off with an Octura X442 or X447. Make a couple of passes & use an IR temp gage to check motor at the shaft, ESC, and LIPOS. Motro/ESC should be at <130 degrees. If the temps are OK it could be proped up using the X6xx series as they have more pitch.
one of the reasons Jay
JIM
