soldering
  • SweetZ28
    • 1535
    Yes but silver solder is better less resistance with silver means better power flow .
    WWW.PPRSLOTS.COM
    • SJFE
      • 4867
      I use a 240watt gun for batteries...I hate sitting around and waiting for the iron to heat the work.
      • saleens7
        • 1130
        my soldering gun heats almost instantly (give it about 5 seconds and its ready to solder)
        ill check out the silver solder (i can probably get it at home depot though)
        saleens7, the wookie of rc boating
        • SweetZ28
          • 1535
          Nope this is resion core with 4% silver normal solder you buy at most places is only 2% silver not as good.
          WWW.PPRSLOTS.COM
          • Diegoboy
            • Mar 2007
            • 7444
            I use a Tin/Lead ratio of 63/37 due to it's lack of a plastic state. Solder joints that are disturbed (moved) during the plastic state will result in damaged connections. For this reason, 63/37 solder is the best alloy for electronic work. Solder with 60/40 alloy is also acceptable, but it goes into a plastic state between 361 and 370 degrees Fahrenheit. When soldering joints with 60/40 alloy, you must exercise extreme care to prevent movement of the component during cooling.
            • Steven Vaccaro
              Administrator
              • 8934
              I use a xy tronic. Its pretty inexpensive and has lasted about 5 years so far!
              Steven Vaccaro
              • saleens7
                • 1130
                i think ill use the silver solder....
