i have a 40" genesis cat, 200a swordfish esc, 435 prop, what motor would yall suggest for some decent speed(50ish mph), i can change the prop if needed just want to get a better motor than the stock 2075 that came with the boat.
motor suggestions
Tags: None
Hey camarohrod,
I don't know what size motor you need, or feel qualified enough to suggest one. However, this site has a pretty useful tool- the Speed Calc. ( http://www.offshoreelectrics.com/conversion.htm ). Also, there are charts on fighterecat's website, if you join, under resources.
id like to get one that will fit into my motor mounts, im not sure the size of my motor now but here is a pic, and i was lookin to spend around 90ish if that will get me a good motor.
Are you sure the prop you have is a 435? As in an Octura X435? Maybe since I dont know some other numerical designation its not what I think. But a 40" hull using a 35mm prop? I'm thinking your off by quite a bit. Another question. Is that a 36mm motor? And is the kv 2075? 4S is not too bad. 6S? Oooch. 6S on a 2075 kv motor even with a small prop. 35mm will not get you 50mph.
JohnChange is the one Constant
How about $88ish?Originally posted by camarohrod View Posti was lookin to spend around 90ish if that will get me a good motor.
4 pole, much higher efficiency, and will fit right into your stock mount. The 1900 or 2200kv are what you need for 4s and the 1400kv for 6s
http://www.offshoreelectrics.com/pro...o-3674&cat=148NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Thats the set-up i have.4082/2200kv leo and a 200 amp swordfish.I will be running two 4s 45-90c 5000mah in parallel.I will be using an Octura 442 for starters.I haven't taken this boat on its maiden yet,so i have no idea of speed or temps.I have too many projects going on!!
m445NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
i wana upgrade basically all the electronics in my boat, i have ordered a 200a esc and i can change my prop no problem just wana know what i need to go with. im new to boats so i have no clue about all this stuff yet, i have loved the water and live on a river plenty big enough to play on so i want a good setup and my neighbor is about to get into this also. what do you think i will get out of the stock motor with that 200a esc and that prop? will it hurt the esc if i run it like that for a little while or do i need to go ahead and order a motor and prop? the prop says TFL 435 it so im guessing thats the size of it.Originally posted by m4a1usr View PostAre you sure the prop you have is a 435? As in an Octura X435? Maybe since I dont know some other numerical designation its not what I think. But a 40" hull using a 35mm prop? I'm thinking your off by quite a bit. Another question. Is that a 36mm motor? And is the kv 2075? 4S is not too bad. 6S? Oooch. 6S on a 2075 kv motor even with a small prop. 35mm will not get you 50mph.
John
Which setup? He asked for a motor that would fit right into his mount so I posted the 3674 Leopard..........but now folks are talking 4082's................the 4082 on 4s with an m445 will see 50+ mph...........NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
