GTX from Heiko
    You mean speed up the one prop while slowing the other to make it steer. I have one made here but have not tried it on its own. As a helper to the rudder it works
    • FOSSILE
      • Aug 2011
      • 22
      #32
      exactly but for the fisrt test I will not put the rudder, to see if it's enough.
      if the result is bad, I'll move to the usual system only rudder.
        Ahh, the setup makes sense now: long stingers and close props. Good for you bud. I have been wondering if it can work. I could certainly clean up the back end of my Komodo by turfing that oversize 'scale' rudder. One mor suggestion then since I have dabbled with my mixing circuit, run batteries into one junction then to controllers. Had mine setup as one batt into one control into one motor and really heated up one battery from one motor working too hard.
        And it did not take much input to help that rudder out.
        • FOSSILE
          • Aug 2011
          • 22
          #34
          GTX launch
          first test 20% throttle
