Made a couple runs with the new leopards 2860's
  • wht73
    • Feb 2012
    • 113
    Well I made a few passes with the new Leopard 2860/3400 kv mtrs. (Thanks Steven V)
    1st run with my sons 11.2's 45/90c with 36mm 3 blade red Venom props. 47.8mph
    Motor temps were 75ish deg with my IR gun on the back of the can, esc's were 85deg.
    2nd run with my 14.8 40/50c same props 57.7mph. Temps were 94 on the back of the can and the esc's were 115/120deg
    I would like to try my 40mm cf props with both voltage batteries.
    What is a safe temp for the esc's and motors?
    What should the timing be for these or inrunner motors?
    The boat is a EKOS twin cat.
    Thanks in advance,
    Chris
  • JIM MARCUM
    • Jun 2011
    • 775
    130-140 degrees is "safe". I've ran my leopards at 170-180 with no issues - yet. I wouldn't push it past that. JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
    • wht73
      • Feb 2012
      • 113
      The 130-140 degrees is the motor temp or the esc or both?
      • JIM MARCUM
        • Jun 2011
        • 775
        That 170-180 was the motor. The T-180 esc ran around 130 degrees. JIM
        • wht73
          • Feb 2012
          • 113
          I'm using 120a esc's. Any thoughts on timing for these or inrunner motors
          • JIM MARCUM
            • Jun 2011
            • 775
            Here's a quote from Fluid on another thread:
            "The numbers 2, 3, 4 etc are the number of turns on the motor stator. You really don't need to know this, the motor size, number of poles and Kv (rpm/volt) are more important. As for the Wye (Y) and Delta (D) winding configurations; while these do have different power characteristics, the most important part is the timing advance they require. A D wind runs 0-4* advance, the Y from 5-15*.
            I too recommend The Leopard 4074/1400 motor. Just keep the prop small or you'll burn up the ESC or motor, or overheat the cells; start with an m445 and work up to an m645. I ran 89 mph with this hull using a Castle 1515/1Y on 6S, but that was a SAW-only setup pulling 200-220 amps. 60 mpg should be a snap."
            JIM
            • JIM MARCUM
              • Jun 2011
              • 775
              Also, check the thread titled "Help understand brushless motor specs". Lots of good info there. JIM
              • carlcisneros
                • Jan 2010
                • 1237
                Jim;
                Wish I could get 60 mpg from my set up as well.
                I had to man (smile)
                • wht73
                  • Feb 2012
                  • 113
                  So I would be ok with the 40mm cf props checking temps ?
                  I'm still learning this prop stuff. M445= 4 pitch, 45 diameter?
                  I'm off to prop talk !
                  • martin
                    • 2881
                    That leopard motor is a D wind so as stated 0-4 degrees timing, re pitch thats a 1.4 ratio x diam so 1.4 x 45mm = 63mm pitch or 2.48".
                    • wht73
                      • Feb 2012
                      • 113
                      Well, I "tried" the 40mm cf props in within the 2nd pass starting out easy to full throttle the starboard side lost 2/3 of it's blades. The boat was 75yds from me when I noticed it
                      so I couldn't tell if I hit something.
                      Is this somewhat common with this style prop? Can I just get a replacement or should I just by 2?
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        The motors are D winds.................7.5* or less.
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          Yep, at high rpms they throw blades..............you need metal props............maybe x442's in R and L on 3s.
                          • JIM MARCUM
                            • Jun 2011
                            • 775
                            Plastic/Carbon composit props won't last one run with FE boats. To hit the pedal you gotta have metal. JIM
                            • wht73
                              • Feb 2012
                              • 113
                              Jim, is there a thread that I can use to get familiar with all tha rc boating lingo? What is "fe" boat?
