P spec ?
  • blizard05
    • Jun 2007
    • 585
    P spec ?
    What makes a P spec boat,motor,esc,battery? thanks Larry
    America home of the free, thanks to the brave [/url]
  • JIM MARCUM
    • 775
    Larry, here's a summary of current NAMBA P-Limited rules.
    NAMBA P Limited (P-Spec)
    Hull lenght: 34" max
    Batteries: 10.1-15 volts
    Motors: Any single motor from the approved motor list:
    d) P-Limited Approved Motors
    i) The motors shall be used as shipped from the manufacturer, with the
    exception of creating a drive shaft flat spot, adding water cooling, and
    allowing the motor to be connected to the ESC by any means.
    ii) Currently approved motors
    Brand Model Description
    AquaCraft AQUG7000 L36/56 7.2-18V – 6 pole brushless
    AQUG7001 36-56-2030 – 6 pole brushless
    AQUG7002 36-56-1800 – 6 pole brushless
    Himax HB3630 1500 brushless – 6 pole brushless
    ProBoat PRB3310 A3630-1500 – 6 pole brushless
    PRB4017 A3630-1800 – 6 pole brushless
    iii) In addition, the CD has the discretion to allow the following:
    (a) An aftermarket motor that is a re-labeled and exact copy of any
    approved motor.
    (b) Any generational change of an approved motor, or a motor that
    is used in a Ready To Run (RTR) offering from a manufacturer
    that produces over 100 units of said offering, as long as there is
    no more than a 5% increase in any of the following
    manufacturers specifications as compared to any single
    approved motor: Kv, maximum constant amperage rating,
    mass, and MSRP.
    (c) The race flyer shall list additional allowed motors for the event
    There are no rules governing ESCs, radio gear, hardware or props. All NAMBA rules can be found at http://www.namba.com/content/library...a_rulebook.pdf
    JIM
    • blizard05
      • Jun 2007
      • 585
      Thanks, how do you power your RX bec or other?
      • JIM MARCUM
        • 775
        Both. depends on the ESC. JIM
        • blizard05
          • Jun 2007
          • 585
          ESC with no bec, how do you power it ? 6volt pack,or other
          • TheShaughnessy
            • 1461
            that would work, or an external bec
            • blizard05
              • Jun 2007
              • 585
              Link to external BEC, what voltage?
                What are the voltage limits of your specific receiver and servo? Those are the limits for an external BEC output. Some run a 2S lipo although many servos will not like that much juice.
                You will find that if you need a part for your boat, the first place to look yourself is OSE.
                http://www.offshoreelectrics.com/pro...le-bec&cat=136
                http://www.offshoreelectrics.com/pro...ortbec&cat=136
                http://www.offshoreelectrics.com/pro...004-01&cat=136
