need more flow for outboard cooling
  • haggis
    • Aug 2011
    • 59
    Made a new cavitation plate on the hor racing outboard with the intake behind the prop but ive tested it in the bath and it seems a bit weak
    anybody got any suggestions?
    www.redbayboats.com
  • jamespl
    • 748
    Surely it won't work in the bath as the boat isn't moving along? The prop may put a tiny bit of water through but you won't get anywhere near the flow as you would if the boat was doing 30mph.
    • haggis
      • Aug 2011
      • 59
      i thought behind the prop would be the best place for it but maybe im wrong.
      suppose ill just have to test it properly.
      www.redbayboats.com
      • carlcisneros
        • Jan 2010
        • 1237
        Haggis
        get it out on the water to test it out.
        It looks proper in the pic.
        never test water flow in the tub.......................
        • jamespl
          • 748
          It's in the same place as the Proboat stiletto and it worked fine on mine. Should be fine, as said get it out on the water.
          • Chrisg81983
            • Jul 2011
            • 1585
            Looks good to me u need to get it moving more than you can do in a tup to notice water flow even though the prop is pushing water on it thats still not enough by itself
            Chris g
            • haggis
              • Aug 2011
              • 59
              Well I tested it and it seems to be working fine. Not quite the jet of water i expected but the tiny motor didnt get too hot
              cheers lads
              www.redbayboats.com
              • carlcisneros
                • Jan 2010
                • 1237
                Haggis
                That looks really good guy.
                very nice running boat you got there.
                am very impressed.
                • noah
                  • May 2012
                  • 13
                  what size prop is on your outboard and if you could post a link that would be awsome
