First run of the season!!!
  • liteumup69
    • May 2011
    • 156
    Hey all, I just ran my titan 40 for the first time this year!! WHAT A DAY, I'm in upstate NY and it almost hit 80 degrees today! Boat ran pretty good, leans to the right a bit, maybe a trim tab adjustment, The castle ICE200HV performed flawlessly, the only issue, seems like I'm loosing signal??? The motor cuts in and out a bit. I don't know whats going on. I'm using a futaba radio AM, I do have a Futaba 3pkMX 2.4 ghz, just haven't had time to swap it out, I've never had an issue with this radio/receiver in the past with any of my nitro trucks.. Also the logger on that esc is pretty neat, Im running a leopard 4082 2200KV on 3s It pulled 24000 rpm and then I tried two 3s packs in series quick, 34,000 rpm and no temps went over 90, I didn't hammer on it, only in the straights for a sec. I think I will go with a lower KV motor, say 1500KV or there about and stick with the 6's, its more fun!!!!! Chat later Paul
  • morewattsnow
    • Oct 2010
    • 236
    Where in NY are you? I'm about 15 miles east of Poughkeepsie. You may be running into the soft cutoff on the speed control- get yourself the Castlelink, it works great. Mike
    Fast Electrics Have A Small Carbon Wake
    • liteumup69
      • May 2011
      • 156
      Im just outside of Troy Ny, I do have the castle link, Are you talking about the lipo cutoff, is so its set at 3.0volt
        I would bump that cutoff up a bit.I run mine at 3.4-3.5.
        • liteumup69
          • May 2011
          • 156
          will give it a try, thanks.
