Feigao 9xl motor with bent shaft ?
    Hi,
    Are feigao motor worth trying to fix ?
    My motor some how got a bent shaft on it, I was running friday and it stopped on me.
    I got it in and had about 3/4" water in the hull,
    And motor and esc hot.
    So I let every cool and dry out and then tried it on the bench and it work ok.
    Today I went to run it, And when I plug in the cells the motor tones were low,
    but it ran on the table so I put it in the pond and it stuttered and I think I saw smoke.
    I looked inside and all was good, But hot and cells were warm.
    Check esc on bench and its still goog and cells are ok.
    Thanks for any info.
  • Make-a-Wake
    FE Rules!
    • 6057
    Not worth messin with in my opinion...................just replace it with one of the great new Turnigy 4 pole 9xl's
    http://www.hobbyking.com/hobbyking/s..._Inrunner.html
      Thanks for link and input.
      Just not sure why it bent,
      I never heard of motors shaft doing that, In less you drop them on the shaft.
      I have a 4074 2200kv I may try or the t600 1400kv.
      • BHChieftain
        Fast Electric Addict
        • 2051
        I had a fiegao that had a bad bearing and the rotor shaft would get REALLY hot-- if this happened and your boat flooded with cold water that might have warped it. If you get another one, run it for 2 minutes, bring it in, and check that the shaft is cool-- it should NOT be hot... only the can should get warm...
        Chief
        • FRED
          • Jul 2007
          • 232
          I'm dumb; 9xl- how can you tell if it's a 9xl. I have a 2860-B-2700 and 3674-B-2200. Help me out Make-a Wake. I'm retired and came from brushed era, oh yes, Thanks! I'm using 3S lipos with a 42 x 55 prop.
          • Make-a-Wake
            FE Rules!
            • 6057
            Fred, your 3674 2200kv is basically a 7xl.........................to be almost exact its a 7.5xl..................LOL
            You can run 4s with the 3674, but the 2860 is definately a 3s motor.
            • lectriglide
              • 540
              Lenny - if you're going to trash the motor shoot me a PM. I screwed up one of the end bells in mine.
              • Make-a-Wake
                FE Rules!
                • 6057
                I have a 3674 that i fried on the first use...................plugged it in and it went to WOT til the magnet shattered.........
                You are welcome to the whole can and endbells lectriglide
                  I had to look inside to see what it looked like.
                  If you need it let me know.
                    Ok, Up date.
                    I am putting a Leopard 4074 2200kv back in my 36"Shockwave,
                    And need To know what the timing should be set at please,
