I recently picked up a Rivercat hull and hardware from Ben at Fightercat. I had the first run yesterday and noticed something strange. while cruising, there was water spraying upwards from the rudder assembly area. At first I thought the cooling line may have a small hole in it but it was fine. Its also fastened snug by clamps to both the rudder and water inlet entering the hull. The strange thing is the fact the water outlet is on the side of the boat. Has anyone seen this before. there is plenty of water circulating through the ESC and the motor cooling can. someone mentioned it maybe the prop causing this. I am running an m445 on this setup.
Any help is appreciated.
