Hydra 240 wires and connectors.
  • H&MWill
    • 680
    Hi, I just got my first Hydra 240 ESC. I saw another thread that says to put both red input wires in one connector and the same with the black. I am running 2 2s1p Lipos in series. Is this the right way to do this? Also do I do the smae with the six output wires? Do I put the 2 like colors together in one connector for a total of 3 connectors? Thanks for any help.
    Also why the 10 total wires instead of just the normal 5? Sorry about all the questions but I just dont get it.
    Many issues!!!
  • Ub Hauled
    • 3051
    See picture...
    does that help?
    CC made it this way so they did not have to put an 8ga wire instead, which is not
    as flexible as this 2 are.
    • H&MWill
      • 680
      That is what I needed and that makes sense. Thanks man
      Many issues!!!
      • H&MWill
        • 680
        Also has can I get away with still using bec or no? I run 4s in my SV and still have it hooked up with no problems.
        Many issues!!!
        • Ub Hauled
          • 3051
          ON 4S I'd go opto... otherwise the BEC board heats up too much... besides, you get less interference.
          • H&MWill
            • 680
            Cool thanks! Will the LVC still work without bec and using a seperate RX pack?
            Many issues!!!
            • Heath M
              • Mar 2008
              • 865
              hey Jan,
              Doesn't it say in the instructions not to cut the motor wires
              Heath
              Brisbane,QLD, Aussie
              • Ub Hauled
                • 3051
                not sure, but if they do, then the entire RC community is in trouble.
                :D
                Seriously, I don't think it is in the manual, did you see it? I know that they mention
                not to cut the wires on the motors. By cutting the wires on the ESC you'll get less resistance thus reducing heat. Cut it enough that it'll fit your system w/o problems.
                The picture you see above is my SAW ESC, so I made sure to cut it as short as possible not only to diminish heat but also to have it fit in my rigger:D
                • Mich. Maniac
                  • 1456
                  dont mean to hijack thread but ofcourse I must!heehee . WHY use a hydra 240 on a sv motor or even a feigao?? They are only rated for like 70Amps anyway. I know some headroom is desired so go for the 120. I just dont get it. Im not saying your using a feigao cause you didnt specify but I see guys using the hydra 240 for feigao's and kb45's. I think neu motors are rated much higher but unless your going for a NAT title then why????
                  • H&MWill
                    • 680
                    Mike, Im sorry I thought Said something and didnt. I am running 4S in my stock Sv with BEC still hooked up. The hydra is in a Triton with a NEU 1515 1Y. I know huge difference. Sorry for not being clearer.
                    Many issues!!!
                    • Ub Hauled
                      • 3051
                      Heheheh...
                      you don't HAVE to use a 240 in your SV.
                      It is a good idea to buy as powerful as you can get so as soon you upgrade
                      your boat or power system you already have a rock solid ESC... besides it'll run cooler
                      and save your equipment from wear.
