New Outboard Drive from HOR
  • iamandrew
    • 576
    thats a biiig carbon plate on it!
    Id preffer to have a more sealed type of can motor with a cooling jacket instead of the outrunner
  • ice_spy
    • 136
    Nice, but i dont like the water pick up in front of the prop. maybe you could extend the cav plate and put the pick up just behind the prop for better forced cooling. If you were to run the motor high, not sure if that pick up would still be in the water. But for $90 with a can..... what a bargin!
    I do like the water cooled mount also, and you could still run a jacket around an inrunner for extra cooling. plus being alloy, it would pull alot more heat out of the motor than your carbon/plastic outboards going for approx. the same price with no motor.....
    Thanks Iamandrew, can see myself putting one of these on my F1 tunnel when i decide to upgrade my set up.
    • dana
      • Mar 2010
      • 3660
      looks cool other than that giant carbon plate. i agree, making something a little sleeker with the pickup behind the prop would be better, and easier.
      • Darin Jordan
        • 9446
        The lower unit, below the cav plate, looks "chunky"... Would be interesting to see a side-by-side, from the front, of this unit next to the others...
        Darin E. Jordan - Renton, WA
        • carlcisneros
          • Jan 2010
          • 1237
          one could always trim the cav plate and install a water pick up that extends behind the prop for proper
          water pick up.
          • siberianhusky
            • Dec 2009
            • 2206
            Don't know if I like how the motor mount plate is supported by two legs on the back side only, could see that flexing with the weight of the motor and pounding of the boat at speed. Would have been easy to support it on all 4 corners.
            Also be nice to know if it uses available stub shafts and flexes. No info at all about spare parts. LOL could end up as a 90$ paper weight!
            Think I'll stick with outboards I know I can get parts for from a number of retailers.
            • AlanN
              • Mar 2008
              • 334
              I don't see the cable size stated. The cav plate can easily be replaced.
              • Boaterguy
                • 1779
                note how thin the wires on the motor are
                • Rumdog
                  • 6667
                  dude, it's a 3s 420 watt outrunner.
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    Yep.
                    • Boaterguy
                      • 1779
                      yes, what kinda hull can that push?
                      • iamandrew
                        • 576
                        theres a lot of small tunnel hull cats around that this would fit on.
                        I guess the big carbon plate can stop some of the wash from going up on the motor and can plane at 5 knots hahaha
                        • karlhh
                          • 104
                          has anyone ordered from here (http://www.horracing.com) before? if so were there any issues? and how fast was shipping?
                          • LarrysDrifter
                            Big Booty Daddy
                            • 3416
                            Everyone, just buy from a known o.b. manufactuer. No offense to the o.p. as he was making us aware of something new.
                            • iamandrew
                              • 576
                              yeah ive bought from HOR a few times, unfortunately sometimes things have been missing from the order, or the wrong part was sent.
                              E,g, motor with 8mm shaft, a 3/16 drive shaft, yet a 8mm to 1/4 collet was sent.
                              He sells a lot of TFL looking stuff , so the outboard leg might be from some other hull setup.
                              usually gets about 2 week shipping time.
