I am building a 42" MRP Fountain the boat is like 20 years old, hull is in great shape and is very light. I am set on the Turnigy t600 motor (run two in an MHZ cat, the torque is brutal), and will be running on 4-5s.I have decided on:
3/16" flex shaft
Hobbyking vanquish rudder/strut
Turnigy 180A esc
Turnigy T600
The problem is I'm not sure of the KV rating for the motor. I run twin 1400s in the mhz, but should I run something lower since this is a big boat operating on a single(looking to keep heat low)? I really just want the boat to hit 30mph, the water is more often rough than not where I live so high speed runs never really work out too well anyway.
3/16" flex shaft
Turnigy 180A esc
Turnigy T600
I have never really heard much about larger props vs smaller ones spinning faster and the torque effects............just seems to me that less diameter would be best. The hull is ABSURDLY light.................... and I added trim tabs to keep it from leaning so bad under acceleration especially. The keel lline is straight as an arrow from the transom til about 4 inches to the tip of the bow..............old school i guess, and i have a bit of positive in the stinger and batts back as far as they can go.
