Willl more timing make outrunner run hot ?
    • 4297
    Hi,
    I have a outrunner and I think timing is 15*on it,
    But it runs a little hot I think, 4 minutes on 4s 175 f.
    If I move the timing up will it run cooler ?
    Thanks for any info.
  • JimClark
    • 5902
    what boat and prop ys using lenny
    Billy Graham
      • 4297
      P1 35" KOS with a s215 or m440 prop.
      • Boaterguy
        • 1760
        what outrunner is it?
        the suppo outrunners on fightercat say 30*, 15 minimum.
          • 4297
          Hi,
          Its the stock venom motor 2000kv, I ran this one on 15*timing on 4s2p with a x640 and temps were 175 f, Esc caps 154 f, Esc 105 f.
          I just thought it may run cooler with more timing,
          But also I just saw that the x640 prop I used was not s&b right.
          I also have two fightercat outrunners 3126 2200kv and 1600kv, I have not tried them yet.
          Trying to see the differents in them running in the boat.
          • stadiumyamaha
            • 1284
            I spoke to castle about the cc outrunner I'm using in a geico about heat issues. They told me that outrunners run hotter than I runners and that they like higher timing. I've bumped my timing up to 18.5 and it brought the temps down.
              • 4297
              Ok thanks for that info,
              That is what I was thinking of doing,
              I think the prop did not help ether.lol
              The seaking esc timing card has these timing I can try 18.75*, 22.50*, 26.25*.
              I just thought I would ask on hear first, Before I burn something up.
              • Boaterguy
                • 1760
                with cap temps that high it implies you do not have enough power from your packs, what packs are they?
                  • 4297
                  So far I used turnigy 4s2p 30 to 40c 3600mah and 4s2p 40 to 50c 3000mah,
                  And 0ne G force ex 3s1p 30c 5000mah.
                  If it was the packs they should be hot, I would think.
                  • Boaterguy
                    • 1760
                    true, the packs would heat up, but your caps are pretty hot.
                    try two runs back to back after your components cool, one with 15* and one with 18.75* and compare temps.
