DF33 Issues
  • robinator63
    • 229
    DF33 Issues
    I am trying to iron out an issue I have with my DF33. I built this boat up over the last couple of months and it just
    not want to cooperate.
    The boat has been calibrated to my transmitter and sounds like it is spinning up fine unloaded. When I launch it
    into the water it moves out with great power until I nail it. Then it goes into "limp mode". Seems like about 25% of
    what the motor is capable of. Do esc's have current limit capabilities? It seems to be going into some type of protection mode.
    Timing issue?? Help!
    1.) Delta Force 33
    2.) Leopard 4074 2000 kVA
    3.) Hobbywing 120A esc.
    4.) Flysky FS-GT2 Radio
    5.) Octura M445 B/S/P
  • Jabbo
    • Jul 2009
    • 495
    What batteries? 4s 2p or 4s 1p?
    • robinator63
      • 229
      4s2p Have tried many batteries. Taken them out, put them in other boats and ran fine.
      • carlcisneros
        • Jan 2010
        • 1237
        the ESC is calibrated to the transmitter?
        the Low voltage cut off is turned off?
        the batteries are at least a 30-35C rating?
        the batteries are at least a 4000mah rating?
        just a few things that need to be answered to see what might be going on.
        please let us know
        thanks
        • Jabbo
          • Jul 2009
          • 495
          You are probably pushing that esc to it's limit try a smaller prop and see what that does.
          • dana
            • Mar 2010
            • 3660
            Try a different radio
            • robinator63
              • 229
              The esc has been calibrated to the transmitter. Today I calibrated it 3 times.
              ESC is set for 4 cell operation. Beeps 4 times when bat is connected.
              Batteries are 40C 4000mAh.
              I know this setup is pushing this esc. But it seems like it would TRY. I have many boats and setups but this is weird.
              • rcboatmanwithkids2880
                • 348
                Think it may be the LVC , as I had the same trouble With my T120 when I was new to the hobby . Just reprogram it off & hopefully that makes your boat fly. ....
                Brad
                Oz
                Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
                • Rumdog
                  • 6667
                  You need a better speed controller. 120 is not enough. Don't even try it again unless you like smoke and stink.
                  prop?
                  • robinator63
                    • 229
                    Ha! I understand this esc could smoke at any second. But I just wanted to get her wet!!!! Maybe it is operating in LVC. This esc is very limited in
                    parameters for operation. It is basically a POS, but I had it laying around and thought it would at least plane the boat off.
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3416
                      Install a 180 amp speedo. Also,move your trim tabs closer to the stinger. Remove the turn fins too.
                      • robinator63
                        • 229
                        Why would you want the LVC to be off? Is that not the reason to have a Lipo capable esc??
                        • robinator63
                          • 229
                          Thanks for the info guys. I guess basically this esc belongs in a SV27 on a good day!! Oh yeah, with the LVC off. Pity.
                          • jasoncyclone
                            • 495
                            Does your radio have ABS? Is so turn it off.
                            Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
                            • LiPo Power
                              DJI Drone Advanced Pilot
                              • 3678
                              Bingo!!!
                              Your ESC has a little brain giving you a hint not to use it.
                              Keep it for a smaller boat or alse .......
                              prop?
                              Canada
