Where to buy 36mm and larger motor mounts???
  • JIM MARCUM
    • Jun 2011
    • 775
    Anyone know where you can buy motor mounts for 36mm-40mm motors? JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
  • Make-a-Wake
    FE Rules!
    • 6057
    Are you wanting mounts that accept both sizes?
    Cuz here's a 36mm http://www.offshoreelectrics.com/pro...prod=ose-80210
    I've put 40mm motors on 36mm mounts and just changed out the rear support ring.
    • JIM MARCUM
      • Jun 2011
      • 775
      Are all 540 size motors 36mm? I already bought this from ebay. Mabe it will do the job. JIM http://www.ebay.com/itm/Xpower-B36-5...item2c617fe186
      • Make-a-Wake
        FE Rules!
        • 6057
        Thats cool! I'm thinking it would also accept motors with larger mount spacing by simply turning the motor and using a broader diameter of the slots. Looks solid enough to use with no rear support ring, but you can always stick a piece of thick foam under the tail as i have done a few times.
        • JIM MARCUM
          • Jun 2011
          • 775
          Glad you like it. I'll know in a week or so how well this works. If it's close I can modify it to work. Then I'll buy two more for my Mean Machine build.
          I was a close tolerance sheetmetal guy for years & can make almost anything with metal. But, with such low prices for mounts etc., my time is filled with tweaking & modifying rather than building from scratch. JIM
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Jim, that looks like a nice mount; I might want to kick in to your next order just to experiment with. I'm not yet convinced that a water-cooled mount is necessary or worth the extra plumbing for inrunners although I used one recently on a project boat I just built and the extra water path hasn't lessened the flow.
            I've been thinking about this one- needs epoxying together once the angle is determined but simple enough :
            The ETTIE mount is a nice one, I have one in my Drifter - most here are out of stock, but ETTI HK has them :
            http://www.etti.com.hk/index.php?cPath=13
            I use an Insane FE 30 mount on my single motor Mean Machine - STRONG but needs a stiff piece of real estate to epoxy it to (I use 3/32" birch ply)
            and premium epoxy like West System G-Flex.
            • JIM MARCUM
              • Jun 2011
              • 775
              Tony, I ordered 2 more today. You can have one of them. If you want more just let me know & will buy as many as you want. Plus, the shipping costs are combined on multiples.
              I made a mount similar to Insane FE 30 mount for my single Apparition and it worked OK. I took it out when I re-glassed the hull cuz I was looking for a mount that's adjustable in both angle & height to compensate for stuffing tube adjustments. JIM
              • Boaterguy
                • 1779
                Fightercat has some nice mounts for bigger motors.
                • Jeff Wohlt
                  • 2740
                  I have the 36 and 40mm mounts. Same as I thhink OSE has. They are about the best out there for strength and support.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
