If you had $250 to buy a hull (preferably with hardware) what would you get? I really like the mmp rapid. But they are located in Czech so I don't know about gettin it since since I'm I'm the states. Thanks for the help
Best deep-vee hull 30"+ to build ($250 budget)
Tags: None
do you have 250 for everything or just the hull and hardware?
if it's just for the hull and hardware, go for the bling rocket 32" (same as a prince) or a DF33
if it's for everything, you'll likely need to step down in size to a 26" bling rocket, what do you already have available?
No its $250 for the hull and i would love for the hardware to be included in that price but if it isn't it will just mean it is going to take me a little bit longer for me to build it.
I am going to want to use it for racing in the future but for now it will be just fun, maybe racing against my friends spartan...I would like to beat a spartan on 6s
I found a website that is selling MMP Rapid/Racemaster hulls for $190 and i think that will be the hull i am getting unless i hear opinions pro or con about other hulls...But i also liked the DF Pirate....
I am just a little apprehensive about cutting holes and stuff since i have never used fiberglass or epoxy or anything, but i am a quick learner...
Only one way to learn. Work slow, measure, double check, and post a build thread and search your hull on here. Itll make you nervous at first, but its really not hard to assemble a boat. Open your wallet, use good drill bits, and dont buy epoxy from home centers.
awesome, thanks for the tips.... and where do you recommend to get the epoxy? and like carbon fiber sheets and stuff?Originally posted by LarrysDrifter View PostOnly one way to learn. Work slow, measure, double check, and post a build thread and search your hull on here. Itll make you nervous at first, but its really not hard to assemble a boat. Open your wallet, use good drill bits, and dont buy epoxy from home centers.
The 32 rocket is like the Pursuit, the 26 is like the princeOriginally posted by Boaterguy View Postdo you have 250 for everything or just the hull and hardware?
if it's for everything, you'll likely need to step down in size to a 26" bling rocket, what do you already have available?I'm married with children, you can't scare me!
OSE has expoxy and www.kintecracing.com has carbon fiber sheets as well as fabric. Ive been using Z Poxy finishing resin on the last couple builds with great results. OSE carries it. I am in one way re buildimg my DF33 and will be posting a build thread maybe later this eve depending on how busy I am with the boat. You should be able to get a few tips from the thread. Outrunning a Spartan is nothing, especially when you assemble the boat yourself.
You'd like the df35 pirate for floggin your mates spartan, they handle well and theres lot's of room to work with, good luck.
Use all Speedmaster hardware that you can. The cheap china stuff is a pain and the Speedmaster isnt much more anyway.
Originally posted by millzee View PostYou'd like the df35 pirate for floggin your mates spartan, they handle well and theres lot's of room to work with, good luck.
You are my inspiration to the DF35 Pirate. I saw the boat you donated to the Childrens hospital and wow, it was amazing. Also nice thing you did there. Congrats.
Originally posted by Boaterguy View Postoops, mixed the two up, thanks for the catch 2226
if you need help figuring out what hardware you need to order (after deciding on the hull), just ask and we can let you know your options.
Cool i will definetley need to do that. once i figure out which hull to go with. Thanks for all the helpful info.
Originally posted by LarrysDrifter View PostUse all Speedmaster hardware that you can. The cheap china stuff is a pain and the Speedmaster isnt much more anyway.Thanks for that information it will definately come in handy.Originally posted by LarrysDrifter View PostOSE has expoxy and www.kintecracing.com has carbon fiber sheets as well as fabric. Ive been using Z Poxy finishing resin on the last couple builds with great results. OSE carries it. I am in one way re buildimg my DF33 and will be posting a build thread maybe later this eve depending on how busy I am with the boat. You should be able to get a few tips from the thread. Outrunning a Spartan is nothing, especially when you assemble the boat yourself.
I think i am leaning towards the DF35 Pirate now....
If i get the MMP Rapid, will i NEED to install dual rudders??
this one?
it doesn't look like there are dual rudders on it there.
do it mate, build a pirate so we can watch it run, cheers.
