looking to achieve 70 to 75mph
  • raptormash
    • Feb 2012
    • 151
    34inch fightercat cheetah 4092leopard 1300kv on 8s lipo this will get me between 70 and 75 mph im hoping what do you think. I have not been able to find any videos of this boat running. Does anyone know of any vids.
  • Make-a-Wake
    FE Rules!
    • 6057
    There is a gent on here that reached 80mph+ with i believe to be a 4082 on 8 or 9s in a similar sized boat
    • Make-a-Wake
      FE Rules!
      • 6057
      I found a vid..............
      • rc2266
        • 317
        The cheetah just came out soo the answer is no on the video's
        I'm married with children, you can't scare me!
        • Rumdog
          • 6667
          What makes you think that hull will stay on the water at that speed? It isn't meant to be a SAW cat.
          • raptormash
            • Feb 2012
            • 151
            How do you know it wont stay on the water and thats what ben recommended for what i want to do.
            • iamandrew
              • 576
              Yeah i dont see the point, at that speed crashing that hull you will loose the whole thing, might have to shove the batteries at the front of the hull, not worth the risk
              • JIM MARCUM
                • Jun 2011
                • 775
                If you want to go 70-75 MPH and can afford to loose the boat - go for it. I think you would be better off with a larger cat that won't be wasted in a crash at that speed. i.e. Aeromarine Avenger Pro. JIM http://www.aeromarinerc.com/index.ph...id=40&Itemid=1
                JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                • RIPFENCE
                  • Sep 2009
                  • 1577
                  just go 60 in an oval with that hull..the wide tunnel will probably make it want to fly but who knows for sure until its done..the hpr's and others like the genesis hull are better canidates for high speed passes in a straight line due to the smaller tunnel but will not fair as well as your cheetah as far as turning goes..i am doing a fightercat shocker hoping for 80 myself but is has a thin tunnel section more suited to do so
                  "FE" STANDS FOR FRUSTRATING EXPLOSIONS
                  • Boaterguy
                    • 1779
                    Ben claims to have the cheetah (or was it the fantasm?) up to 80+mph.
                    the genesis would be a good candidate but would not hold up at all without reinforcement in a crash.
                    • RIPFENCE
                      • Sep 2009
                      • 1577
                      definately need to reinforce anything going these speeds
                      • keithbradley
                        • 3671
                        ...Says the guy with the 70mph sprintcat.
                        Do you still have the twin sprintcat?
                        OP:
                        It's really hard to know at this point what the Cheetah will like. A lot of the European guys run in the RPM range you're at with a smaller prop, but they run cats with a relatively narrow tunnel and twin props. The Cheetah will likely be able to handle a decent sized prop, so you might not have to spin it that fast.
                        www.keithbradleyboats.com
                        • Chrisg81983
                          • Jul 2011
                          • 1585
                          I agree any cash above 65 -70 does some damage IMO I hade some crashes at 62 mph that did some decent damage with the hull being reinforced it all depends how the hull hits the water thanks
                          Chris
                          • Chrisg81983
                            • Jul 2011
                            • 1585
                            I agree any cash above 65 -70 does some damage IMO I hade some crashes at 62 mph that did some decent damage with the hull being reinforced it all defends how the hull hits the water thanks Chris
                            • sampit
                              • Jul 2009
                              • 466
                              What strut and rudder are you going to use on your Cheetah
                              I'm building one now 4082 1610kvv or 4092 1600kv 6s single
                              The 32 FC mono stingers didn't fit to go twin drive, so changed to a single setup
                              Now im stuck with not nowing what hardwear that will fit is has a very high transom
                              FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
                              Popeye Hydro T600 1400kv 6s1p
