Help with hull
  • boatbandit2
    • 109
    Help with hull
    Hi
    I was wondering should i full in where i have circled as i am going for single drive not sure?
  • Diegoboy
    • Mar 2007
    • 7443
    Fill with...??
    Skin it? Yes.
    Fill with block foam? I would
    • boatbandit2
      • 109
      Sorry yes skin it
      The plan is from lomdel it has option for twin or single
      Thanks
      Paul
      • rcboatmanwithkids2880
        • 348
        Hi mate ,
        If it does not make contact with water , and an internal concern only , then you are just adding weight. ....
        Brad
        Oz
        Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
        • boatbandit2
          • 109
          Hi Brad
          I will end up with about a 30mm longer rear ride pad not sure if i will gain any performance or lose performance ?
          The plan shows a step up but my guess is thats for twin drive
          Paul
          • boatbandit2
            • 109
            Hi
            Was wondering if i should put another step in the ride pad as the rear ride pad is long any info would be great
            Cheers
            Paul
              • 348
              If your not attending World Championships or after a SAW record , then being so pedantic is ip to you . That hull has steps already , & more than likely that hull has been tested by the manufacturer for efficient ride characteristics so if you do add a step at the rear just for experience more power to you. ....
              Brad
              Oz
