Cracked the transom on my Genesis
  • JonD
    • Jun 2011
    • 135
    I posted this thread a couple of hours ago, and then discovered an earlier thread that Bubblegoose had posted where he had a very similar incident a couple of days ago. Not a good week for busted Genesis transoms His actually seems to have more damage that mine. Mine seems intact around the screws holes where the rudder/strut assembly attach, with the crack to one side only. But I'll need to check it quite carefully. Anyway, probably not much more that anyone can add, to help, that has not already been said. Below is the thread I did before seeing the one from Bubblegoose.
    Today my rudder hit something in the water at full speed. The boat did a full 360 degree somersault and fortunately landed right way up. The safety screw in the rudder sheared allowing the rudder to hinge up. However there is now a crack in the transom from the force of the impact. I went back out in a kayak to check to see if there was a log or anything solid in the water, but couldn't see anything. I think I may have hit a fish - there was a lot about. The water in the lake is only 2 ft deep. No mark impact marks on the rudder.
    The crack is clearly visible on the photos. It goes right through the fiberglass - not just a gel coat crack. It also goes about 1/2 inch around the side (which you can't see in the photos). Looks like it is going to be a devil of a job to get inside the hull at the back to reinforce it with more fiberglass - the space is so constricted.
    Can anyone give me some tips on how to best go about this repair ?
    One other thing. I had replaced the 3mm nylon safety screw with a 3mm brass screw because the nylon screws kept shearing through just from normal use. Someone suggested going to brass, which I did. But I guess this required more load to shear and hence my cracked hull. I am thinking about going back to nylon but going to a 4mm screw instead of the original 3mm.
    Jon
  • Bubblegoose
    • 27
    Hi Jon,
    It sure is a bad week for Genesis transoms lol.
    I just finished repairing mine tonight, And I have a fairly in depth knowledge of the genesis rear end because of it. If all you want to do is just add some strengthening on the inside, I don't think it would be too hard to do, even though there is limited space.
    Remove the motor, esc, servo, receiver. Prop the boat up so the nose is towards the roof (and so it's not resting on the rudder or strut) on a slight angle to the left side. Get some epoxy, and use a long paintbrush to slowly build up a good layer of epoxy in the back of the cavity on the cracked side. Get some close weave glassfibre, and then use something long (not the brush) like a flat head screwdriver etc, to push it down and into the resin. Then dab some more epoxy on until it is covered completely.
    That should be enough to give it the strength back. And I wouldn't worry too much about the crack, the water wont be able to get in, and it's not going to be in the water when the boat is planing, so it won't alter the speed/performance of it.
    Cheers
    • JIM MARCUM
      • Jun 2011
      • 775
      From what I seen, the Genisis, Miss geico, Blackjack, and most Chineese FE boats need reinforcement along the hull seams, transom - or with an Apparition, the motor mount deck - with epoxy and 1-2" fiberglass tape or flexable cloth to survive. Eazy to fix. Clean surface well with acetone and glass away. JIM
      JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
      • JonD
        • Jun 2011
        • 135
        OK, so I have done pretty much what Bubblegoose suggested and encoraged some fibreglass (I used 1 inch fibreglass tape because it doesn't fray so much - at least not in the "long direction" ) down into the bowels of the inside of the transom. Actually doesn't look too bad. Probably stronger than the orignal set up. I decided to use Devcon 2 Ton epoxy as the resin, instead of normal polyester resin. I have had some good results using this resin in the past. Very tough and high impact strength, and very easy to use and dispense with the 50ml Duo-Packs and self mixing nozzles.
        Hopefully I'll be out with the boat again this weekend. Am I the only one who hits fish....?????
        Cheers,
        Jon
        • Bubblegoose
          • 27
          Yay . Someone listened to me for onece :) lol just kidding. I'm just jealous cause u can run yours and I cannot . See my past post to find out why
