delta force votrex hydro 22 question
  • netik racing
    • Jan 2010
    • 60
    so i got a dfv 22 off ebay for $100 with hardware almost ready to run...
    After a few weeks of running the small 540 in it got a bit sick of the slow speed's and the cooking motor...
    So upgraded both the motor and and esc the motor is a 2200kv leopard and a 180amp seaking esc...
    Im running a 40mm 3 blade propshop prop
    Its good for about 90kph and im happy at that..
    The question i have is what sort of turn fin should i use and what size should it be and should it be curved or straight?????
    If anybody has already put one on there hulll could you post some pics up so i know what im doing...
    This is only my second hydro if you can count a small bolt as a REAL hydro
    HOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
  • ryan_t888
    • Dec 2007
    • 69
    Sizing for the turn fin should be somewhere along the lines of 2 inches by 1-1/2 inches. A typical Hydro turn fin curves towards the hull. The best mounting location on that hull is the rear vertical face on the right hand front sponson. You would require a 90 degree bracket in addition to the turn fin.
    Ryan
