flex cable length
  • launchpad
    • 199
    flex cable length
    Hey Guys;
    I am in the process of building a twin motor Genesis,which is my first big build.I have been sitting here scratching my head on how I determine the length of the flex cable.Could someone inform me of what I have to do. Thanks
    Al
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    The shorter the better, "I didnt just say that" ofcause it has to work with COG, the stuffing tubes, drivers/stingers and everything else aswell. the Genesis thread/s may help you out. really depending what setup you are running. you should place everything you intend to use in the hull and find COG. Not sure what that is on a twin Genesis though.
    • launchpad
      • 199
      Hello;
      The cog on the genesis is measured from the back of the sponson to the bow,Mine cog is about 9 7/8" from the bottom of the sponson at the back.I had to take things apart because I measured it the standard way.There has been a few guys that did the same thing.Oh well;weep and learn.Did I ever.
      • highflyerbill
        • Jul 2011
        • 206
        A good place to start would be 30% from rear of sponson . Keep in mind that's just a good starting point , you will have to move it rearward or fwd in small increments to find what the boat likes best .
        • Fastfish
          • Mar 2012
          • 34
          What do you balance the hull on as you moving parts fwd or aft? Just another newbe question...LOL
          • longballlumber
            • 3417
            A wood dowl rod can work....
            Later,
            Mike
            • Fastfish
              • Mar 2012
              • 34
              Thats what I had in mind...Thanks
