the engine mounting point
  • kaistapaa
    • Aug 2011
    • 16
    whether it would be to throw in some recommendations for the motor you want to install 46 "V-hull boat. this body:
    leopard5692 engine and engine mount design, which can be mounted to a point on the longitudinal direction.
  • Diegoboy
    • Mar 2007
    • 7444
    DO you have the boat already or just planning to get one?
    • carlcisneros
      • Jan 2010
      • 1237
      get one of these from Ben.
      I have one and it is a work of art.
      good price on it as well.
      • kaistapaa
        • Aug 2011
        • 16
        yes,i have it allready.
        • Diegoboy
          • Mar 2007
          • 7444
          Start by getting the center of gravity around 30% from the transom.
          You can set the motor near the front of the boat and the batteries set near the transom. this will make installing / removing the batteries easier.
          You can set the motor closer to the transom with the batteries near the front which will give you more versitility with adjusting the COG but may make installing / removing the batteries a bit more troublesom but it depends on the hatch opening.
          Just be sure with all the equipment in the hull have the COG at about 30%
          • kaistapaa
            • Aug 2011
            • 16
            Thank you very much for your reply. install the engine behind because of the relative space is to make the testing of batteries and the esc investments.
