Cg For 29" Mono
  • yz120
    • 236
    Cg For 29" Mono
    starting to build my 29" d/f copy from skunk works and need to know the c/g.
    approx. motor location, batts ect. i will be running 14 ib3600`s and an 9xl for starters.
    any help would be appreciated.
    thank,
    mike
  • Bill-SOCAL
    • Nov 2007
    • 1409
    Set the CG at 33% from the transom ~ 8.7 inches. Locate your motor and batteries so the CG is around that point and fine tune the CG by moving the packs forward or aft as needed.
    Don't get me started
    • Doug Smock
      • 5359
      Hey Mike,
      I build monos so that I can adjust the CG from 27 (7.8") to 30% (8.7"). I prefer to start with the CG aft and move it forward as I tune the boat. It is never good idea to run a boat wet. You'll start loosing equipment.
      Put a piece of masking tape on each side of the deck with the CG marked on it at 27- 30%
      Mount your hardware, lay your mounted motor in the hull approx 7" from the transom with the ESC in front of the motor. Place the servo, rec. and rec. pack where you would like them. (I keep mine as close to the transom as possible.)
      Lay your cells in the hull on each side of the motor. Now move the cells for and aft and see if you can get the CG in the range mentioned above. When you are happy with the layout and CG, mark the componet location. Now get back to building!!!!
      I'd be happy to send you setup pics of some race proven builds.
      Good luck and post some pics,
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Ocean Racer
        • 511
        Sence u are on the subject what if u have a ob does the CG change?
        Failure is the First step to SUCCESS
        • yz120
          • 236
          [QUOTE=D.Smock;32444]Hey Mike,
          doug,
          i would appreciate pics,
          thank you,
          mike
          mlrbrink@redrivernet.com
          • Doug Smock
            • 5359
            I'll send them to you tomorrow afternoon Mike. ( I can't access them on this computer)
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Doug Smock
              • 5359
              Doug
              Let me know if you got them.
              Good luck!,
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • yz120
                • 236
                Good luck!,
                Doug
                got em
                thank you,they will really help out.
                thanks again,
                mike
                also thanks to all that replied to this post.
                • Eodman
                  • 1285
                  Hey Ocean racer, sure the CG changes if you have an outboard(I'm assuming you are refering to an outboard) all that weight is now outside the boat rather than inside!
                  If you don't offset the weight of the motor(s) your CG will move towards the stern!
                  I think!
                  We did it with a Bang!
                  Cats Are Where It's At!
                  • Ocean Racer
                    • 511
                    Its going to move towards the stern? Are u sure its not toward the bow.
                    • Eodman
                      • 1285
                      Unless I'm all wet(& I've been known to be) the center of gravity as I understand it would move to the stern. The CG would move backward to counterbalance the weight of the outboard(s), more hull weight forward to balance it!
                      Take one of your boats find the CG on a broom handle laying on a table .. now place a double a battery in the stern -- what happens? How do you offset the effect of the battery ... by moving the boat further forward on the broom stick ... more of the bow now is forward of the old CG! So the new CG is further back!
                      • Ocean Racer
                        • 511
                        Ok i think i get it now
                        • Ocean Racer
                          • 511
                          Eodman I stated to think about what you were saying and all of a sudden it hit me what you meant. Duh if you put a outboard in the back you need to put weight in the front thus your CG moves back. The only thing I did not get was the broom handle? How do u do that i think i have a idea but i need a little more info.
                          • Eodman
                            • 1285
                            The reason for the broomstick is to act as a fulcrum or balance point on the table!
                            • Ocean Racer
                              • 511
                              do you rest the hull on it? maybe you could put a pic up to help me out im not grasping the idea.
