Lipo pack in TX (GT3B)
  • Diegoboy
    • Mar 2007
    • 7443
    They also have Pre-completed units for those that don't want to open it. There's also an updated voltage regulator for more efficient battery use.
    Thanks Egneg for pointing this information out to me on Saturday.
    • line6
      • 510
      Been using these for some time with good results.
      Jason Sims
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        Originally posted by leebrushless View Post
        Good mod. Where did you hook it in & what LED did you use, if you don't mind sharing? Thanks Leigh
        Leigh,
        I'd have to dig out a parts list - blinking LED, resistor, LED holder. It was a crapshoot to find room for the LED & switch. I lucked out but came dangerously close to drilling into the internals. Best bet is to flash the unit like Diegoboy linked to, to keep the screen on ('tho the screen uses a bit of batt power).
        • leebrushless
          • 13
          Ok. Iam going to get a flash kit & upgraded voltage reg for it & run 3S LiPo. Thanks Leigh
          JAE FE rigger, ul-1, 4s.
          JAE Gas rigger, in progress.
          • egneg
            • 4759
            I got the kit and flashed the firmware on a GT3B as well. It's very straight forward and I ended up with 16 model memory.
            P.S. It does have a variable inactivity alarm as well.
            IMPBA 20481S D-12
              Cool, I might get the kit too, just to get the display to stay lit longer etc...
              I bought a 2500Mah flat pack off ebay for mine for $10 or $15 and took out the battery tray, soldered in new connectors.
